[SOLVED] Low power Current mirror with high output impedance
mretsh91
Junior Member level 3
Can anybody help me with the design of a current mirror with Rout=1 M with 1.2 supply and 0.6 compliance voltage and drive a current of 800u.
1. Is this thread solved??
2. Are you looking for a solution in VLSI level or a Discrete components level.
For High output impedance you should go for a cascoded current mirror. It can be designed to give good mirroring with good compliance voltage.
Thanks a lot for your concern nitishn ...actually I implemented it with a triple cascode design
