jorat134612
Newbie level 2
I'm looking to do a little home project. I want to do my our digital heating control thermostat. So, I'm looking for high power low dissipation electronic component. I don't want to use relay because they are noisy and I want to be able to modulate the voltage too. So far, everything I have seen have an almost direct ratio of 1W for 1A control. On a typical electric header of 40A @ 120VAC, we will have a dissipation of 40W which correspond of a standard light bull. So, at 4800W for a electric header, we have a efficiency of 0.83% which for me is a lot. This also translate in a thermal dissipation which need to be dissipate. I will like to have all my setup fitted in a standard electric light switch box. With a 40W of thermal power to dissipate, it's hard to fit it inside such a little box and also have a room temperature sensor in there too. For what I know it's not possible to find something with a lower power consumption as long as we stick to silicon triac as silicon triac.
So any suggestion of a very high power switch with low power/low dissipation control modulator?
