Jensen
Junior Member level 2
multiple phase noise oscillator
In my new project i may need a low phase noise 160 or 180MHz oscillator for AD9856 ( DDS chip). Someone suggest me to use a 10MHz OCXO to catch lower phase in near-band, in this project the phase noise of DDS output must below -70dBc @10Hz. If i use 10MHz ocxo, then i must use on-chip multipler inside AD9856, it cause some degrade of phase noise. I want to disable the on-chip multipler and use a 160 or 180MHz high stability low phase noise oscillator to meet the performance what i need.
Can I?
I don't know how to design the high ferquency high stability low phase noise oscillator which i need. Could somebody help me?
An other question is how to design a narrow band passive BPF?
Realy narrow band 16.8MHz +/- 2000ppm, 18.4MHz +/-2000ppm
33.8MHz +/-2000ppm, how can i do this???????????
Thanks in advance.
Jensen
Can I?
Thanks in advance.
Jensen
