low pass filter (matlab)
sherifelian
Newbie level 3
Newbie level 3
fir1 matlab
hi all ,
i am supposed to implement an Am modulator and demodulator using Matlab
i have finished the modulator already
but i have a problems in the demodulator
i make an envelope detector ( i make it manually )
but then i want to make low pass filter and i don't know how
i know fir1() and filter() but i don't know how to use them
so anybody can help ???
thanks alot
mro83
Member level 5
Member level 5
Mashad
matlab fir1
Hi
the best way is to read Matlab help. see the matlab entries for commands:
"butter" that u can set it as a LPF .
"filter".
a glance will guide u through.
b.pricope
Junior Member level 2
low pass filter matlab
[num,den] = butter(2, .8 ) ;
FilteredOutput = filter(num,den,DeAmpMod);
where DeAmpMod is the Demodulated AM modulated signal you want to filter.
Good luck!
sherifelian
Newbie level 3
Newbie level 3
matlab lpf
thanks very much for your replies
but
butter(2, .8 )
can you tell me what is the 2 and what is the .8
, another thing , i prefere to work with fir1
as my professor told me to use
so if you can explain to me its parameters
fir1(n,Wn) it will help alot
if no , then butter will do the job
thanks very much you are really saving me :D
claudiocamera
Full Member level 4
Full Member level 4
Salvador-BA-Brazil
lowpass filter matlab
The command fir1 in matlab implements digital filters based on the window methods , as you indicated the comand h=fir1(n,wn) returns the nth +1 coeficients of a Hamming window lowpass linear filter, the vector h is the coeficients of the filter from wich you will convolve the sample demodulated signal. If you want to use other window than hamming, for instance if you need a attenuation in the stopband higher than 44 db you can use h = fir1(n,Wn,window) where widow should be a colum vector resulted from a desired window see blackman and kaiser in the matlab help.
Dont forget that Wn is the normalised frequency i.e the desired cut off frequency over Sampling frequency.
n is the number of coeficient of the filter, it depends of the transition width ( normalized) and the window used, for a hamming window n=3.3/( transition width). Remember to normalize the transition width related to the sampling frequency and that transition width = stopband - passband
After find h from fir1 you can peform as the pall b.pricope suggested :
FilteredOutput = filter(h,1,DeAmpMod);
I hope have helped
sherifelian
Newbie level 3
Newbie level 3
fir1 filter
THNKS ALOT
that really helped me alot , i finished the AM , i hope FM became more Simpler
xuedashun
Member level 1
Member level 1
digital low pass filter matlab
who can recommend book related lpf by matlab ? thanks
b.pricope
lpf matlab
Digital Signal Processing using MATLAB by Proakis is one of the very good books.
You can find it here on the server.
nagacnu
matlab low pass filter butter
here is your req feel free to contact me
cut_of_freq =0.2; %normalised frequency f/fs
N = 11 %order of the filter
h = fir1 (N-1, cut_of_freq, hamming(N));
Y =filter(h,x); % here x is our in put signal
for more about the fir1 go to command window and type help fir1 u can get good information how to use it
mro83
Member level 5
Member level 5
Mashad
how to create a low pass filter using matlab
for xuedashun:
Computer Explorations in SIGNALS AND SYSTEMS (Using Matlab)
BY : John R.Buck (co-author of oppenheim in his DSP book)
and it has a lot of other usages of matlab.
cheers
