1. Roll off are usual slopes (the linear part) of the dB vs log f : they are easy to remember 6 dB /octave or 20 dB /decade. Double them for 2nd order and quad them for a third order filer.
2. The two frequencies are well separated (how do I know?) and hence a first order filter is ok. (you want a 20 dB loss and that means if I use 1000Hz at the corner frequency, 10kHz will be 20dB less)
3. If the upper freq is less than 10kHz, you better use a second order filter. If the two fellows are close by, use a digital filter.
I see KlausST has explained the same solution very succinctly. I also suggest you play with the dB and log f plots and try to work out simple examples by hand (with a calculator).
If a Simple Butterworth Filter will attenuate 20dB@15k Ohmega so the Cut-off frequency will be around 1.5k Ohmega.
Because simple one pole filter 20dB/decade slope.
