pjohn
Newbie level 6
I am designing this very simple low pass filter, and also with the view to drop the Voltage to 3.3v from 24v.
Here are the specs: Cut off frequency: 297 Hz
I started initially with the following combination:
+24v
R1
................C....Ground
R2
Ground
Now the values: R1 = 390K
R2 = 62K
C = 10nF
I am getting the right values in simulation and every thing but I do not seem to make the relationship between these values and known theory that Cut off frequency is calculated as:
F = 1/2*3.14*R*C
If I take R as 390K and C as 10nF (both in series) cut off frequency is about 40 Hz. But as soon as I add (R2) 62K resistor in parallel with the RC Filter, the cut off frequency changes to 298 H. Which is what I require, but why????
I thought R2 is just acting as load and should not effect the cutoff.
Please help me clarify this confusion.
Thanks in advance
+24v
R1
R2
Ground
R2 = 62K
C = 10nF
F = 1/2*3.14*R*C
Thanks in advance
