Analog Devices has low cost log amplifier circuits that will cover that dynamic range. This is clearly the way to go.
Trying to do 70 dB dynamic range with diodes is impractical. You could go to the trouble having a cascaded diode array. Input has a 3 dB splitter with a diode on one arm, and 40 dB gain on the other arm followed by another diode. You could then sum the diode currents with appropriate gain to get a crude power to voltage out. It will be pretty non-linear. At the lowest levels, it is smart to use two diode for each station, 1 with DC bias and RF applied and the 2nd with just DC bias applied. The detected output is the DC difference between diode 1 and 2. If you use two diodes packaged together, this will take out diode junction voltage variations and eliminate maybe 90% of the frequency drift.
If you are really enthralled with trying to do this with diodes, you could consider chopping the RF input at, say a 10 KHz rate, and detecting/amplifying the 10 KHz ac tone out of the diode. This will allow you to go down to lower input RF power readings.
