loop with even and odd input
fanwel
Full Member level 3
Full Member level 3
Hi all,
I try to write a code that will differentiate the input either odd or even for obtain the output.
Below is my code:
package my_data_types is
type vector is array (natural range <>) of integer;
end my_data_types;
library ieee;
use ieee.all;
use work.my_data_types.all;
entity even_odd is
port (clk: in bit;
A: in vector (7 downto 0);
out_odd: out vector (3 downto 0);
out_even: out vector (3 downto 0));
end even_odd;
architecture even_odd of even_odd is
begin
process(clk)
begin
if (clk'event and clk='1') then
for i in 7 downto 0 loop
out_odd <= A(2*i);
--A((2*i)+1);
out_even <= A(2*i-1);
--A((2*i-1)+1);
end loop;
end if;
end process;
end even_odd;
But then, there is an error occurred when I compile the code.
Error (10381): VHDL Type Mismatch error at even_odd.vhd(23): indexed name returns a value whose type does not match "vector", the type of the target expression.
Can anyone help me..where my mistake? Many thanks
the statement A(2*i) (and the -1 version) only return a single bit. But out_odd and out_even are 4 bits long each. I think you meant this:
for i in 3 downto 0 loop  --only 3 downto 0 otherwise you go out of the range of A with i*2
  out_odd(i) <= A(i*2+1);
  out_even(i) <= A(i*2);
end loop;
Hi TrickyDicky,
Sorry, Im not clear with:
for i in 3 downto 0 loop -- it's will only read the input from that range only? Although my input is in range 7 downto 0.
Thanks for reply
yes, but if you look at the code, it will access all 8 bits.
3*2 +1 = 7
3*2 = 6
2*2 + 1 = 5
etc
If you kept it like you did before, it would try and access bit 15 downto 0, and bits 8 to 15 dont exist, so you would get a bad index error.
You are only connecting 4 bits for each output, so you only need to have 4 iterations.
Reactions: fanwel
    fanwel
Hi TrickyDicky,
Okay, i understand now..many thanks for helping me.
