BusyEng
Newbie level 6
Hi all,
I am dealing with a small loop antenna taht is supposed to work at 2.44GHz. My measurements with VNA shows taht the current designed antenna is resonating at 2.64GHz and has a 60MHz bandwidth. Two questions:
1) How can I increase the antenna bandwidth from 60MHz to 200MHz?
2) Can I reduce the resonating frequency from 2.64GHz to 2.44GHz by increasing the loop circumference? (in my current design the loop circumference is 28mm. How much more should I add to the circumference to bring the resonating frequency down from 2.64GHz to 2.44GHz)
Thanks.
Thanks.
