Looking for very bright white LEDs
cube007
Full Member level 6
Full Member level 6
Australia
lck-led
Hello,
I'm looking for very bright white LEDs (SMT or not) for building a LED lamp. Do you have some good information.
Thank you in advance,
cube007
samsuffy
Member level 4
Member level 4
MARL has nice products :
I've already tested 5mm through hole white leds = ~2000mcd
and also smd white leds = ~320 mcd
have a look to marl.co.uk[/url]
Fragrance
East Of Earth
WHITE LED
I have made a white led tourch, idea is that you can achive high brightness with help of white led driver circuit see attachment
Regards
Fragrance
cube007
Full Member level 6
Full Member level 6
Australia
Thank you for the information. I found good products from Osram (Golden Dragon) and Luxeon. Both are producing LEDs with 20lm/W.
by,
cube007
sss123
Junior Member level 1
go to vvv.LCK-LED.c*m you will find many high power leds at good prices.
Beepster
Full Member level 1
unknown
You want the Luxeon 5, star.
It is 5 watts and you can't look at it.
It's 1 led chip.
It burns your eye.
~7.6x Volts.
The star is a alunimum pcb substrate needed to get the heat ( and a lot of it ) to a bigger heat sink.
Not cheep, ~$20 U.S.
pop48m
Junior Member level 2
Is this address correct?
Thanks. Pop
CMOS
Advanced Member level 3
USA
Thanks. Pop
Replace vvv by www and * by o
