Looking for schematics of TV jammers
fpshutch
Newbie level 2
anyone have plans for a tv jammer that i could use on friends and flamily?
Re: jammers
A TV jammer is ilegal. If you have cable TV, you need very high jamming power to jam the channel.
However, if you use a classical antenna, like rabbit ears, you need just a simple sweept oscillator, that covers the respective channels, placed near the antenna.
For friends and family you don't use a jammer :)).
Re: jammers
You are partly in error. It is NOT illegal at all. Some watches (Casio) come with that feature to joke around with it. Maximum distance, however, is about 10 feet. Basically in close proximity of the TV.
Jamming your neighbour's TV is interfering with their right to watch whatever they want, but within the boundries of the law.
Re: jammers
simply, u can jamm anything in ur home & not others. If u hv some complaint with neibours, friends, solve with them peacefully. If they trouble u, then compaint to police. If u want to do this for fun, check that they don't compaint or fight with u.
U can use any sweep generators with high power cable tv amplifer with matching antenna at the output. The type of used antenna will be decisive factor in directivity of signals.
Re: jammers
Hello people,
does anyone konw how to calculate the J/S of a GPS Receiver (data sheet known)...?
Any jelp wil be appreciated,
Lupin
Re: jammers
i need a satallite tv jammer
Re: jammers
For satellite TV jamming the best tool is a simple blanket! :p Cover the parabolic antenna! Or simply the LNB with "invisible", small, Al foil.
The real electrical jamming will be expensive! The satellite broadcasting chanels are around 20 GHz. Considering that parabolic antennas has good side lobe cancellation, because narrow 3 dB angle, you need to pump it hard RF power for jamming.
Considering the prices of f>20 GHz amplifiers... Hmmmm :p
Nice job!
Try the blanket! Or try the IF of the LNB, around 800...900 MHz.
Maybe the cheapest solution is to disassamble an old microwave oven, and marrige it with a high gain helix beam antenna :) But forget this way if you want children and family! (sterilization side effect of 2.45 GHz microwave beam, or cancer or sudden death! NOT FUN!)
Regards,
Zoltan
Re: jammers
Mobile_Phone_Jammers_Second_Report_E.pdf
Re: satellite tv jammer pdf
Why are you going to use tv jammer on your friends and flamily?If you use it ,you can not watch tv and make a cell phone call,just like the **broken link removed**,you should think it clearly.
