Looking for plotter applications
oozmaq
Junior Member level 1
Plotter applications
Salaam
need help finding the applications of a plotter. What are they used for????? what is the difference b/w printer and plotter???? why do we use plotter when we have cheaper printers???????
actually i'm making a mouse following plotter......dats why i need 2 know these things.....
throwaway18
Advanced Member level 2
Kent, UK
A plotter gives a solid line. An injet printer
makes lines out of dots. Plotters are somtimes used to make photomasks for pcb's where you need solid lines, small gaps between dots on a printed mask could make open circuit tracks.
Plotters were generally used for technical drawings such as building plans, mechanical drawings and circuit diagrams. Pen plotters were used twenty years ago when a typical printer was a dot matrix type with poor resoloution.
These days people usually don't use plotters. High resolution inkjet printers are usually used instead of plotters.
I search briefly with google and could not find any new pen plotters for sale.
I bought a secondhand **broken link removed** for almost nothing years ago and used a pen filled with permanent marker ink to plot tracks directly onto copper-clad board to make prototype pcb's, mainly for the novelty. I still have it somewhere but the driver was for windows 3.1, a cheap inkjet is much better and much faster for diagrams and there are lots pcb manufacturers that make single pcb's very cheap.
dipal_z
Full Member level 5
Full Member level 5
India
Plotters were used mainly to draw building plans and mechanical drawings. The main reason behind that was quality and size of the paper you can use in printers.
As explained by throwaway18, plotters use pens and output of plotter is same as hand made drawings, only difference is the pen is moved by electromechanical means instead of hand.
