hughmanoid
Junior Member level 1
- Joined
- Feb 22, 2012
- Messages
- 15
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Santa Cruz CA
- Activity points
- 1,546
I am looking for something similar to an LM2575 BUCK only with an external witch.
I am starting a new post since I am focused on just finding the right IC.
Input power ramps up from 0 to 450 VDC at up to an availabel 15 amps and back down to 0.
The load is a VICOR DC-DC converter rated to run from 200 to 400 VDC, 300 VDC nominal.
Requirement 1 is to act like a series pass regulator that limits output to about 350 VDC
and will still pass current during long periods of dropout down to 200 VDC.
Output current will pass through an inductor and be filtered by a large cap.
Requirement 2 is to start bucking from 375 VCD to 450 VDC.
No need to boost. Just a simple switcher with an external P or N FET or IGbT.
Toss in a bulky toroid, heavy duty high current diode, large 600 VDC cap, and
a couple resistors in a feedback divider.
I can power the chip with 15 volts or so, just need to switch high voltage at
a few amps or more with multiple FETS.
The closest IC I found is an LTC4366 surge protection IC that clamps surges and turns off
a series pass fet before it overheats.
I am hoping to avoid futzing around with discrete comparators, gate drivers, pwm generators
since I don't want to re-invent the freewheel....
Thanks
Thanks
