Looking for noise generator circuit
Wowee
Junior Member level 2
I want to generate white noise in my design.Could somebody provide a cheap circuit.Thanks
flatulent
Advanced Member level 6
Middle Earth
two methods
Here are two methods. If you want an approximation, a maximum length feedback shift register sequence will work.
An electronic method is to reverse bias a BJT base emitter junction with a series resistor to limit the current once it breaks over (Zener action). Follow this with an amplifier to get the level to what you want.
If you want extremely wide band noise there are special tubes you can buy.
se7en
Member level 2
Member level 2
there is specific test equipment on the market
T
THE BORG
Newbie level 1
you can make one from a 5v or 6 v miniture light bulb
just blow the filliment with 12 v paint it with conductive paint paint in a small conductor
and use this too provide a field signal
any field signal is white noise connected too a bjt
some instuments use this approch
as above
but this isnt a special one but its a cheep one
RegUser_2
Full Member level 2
Full Member level 2
Pass a current through a zener diode close to the zener threshold current then AC couple the zener voltage.
