Looking for materials about DSP processors programming
tavakoli
Member level 3
Dsp prosessors
Does anyone know a good site or free ebook about programmnig Dsp processors??
thanx
Re: Dsp prosessors
For Analog devices ADSp series the user manuals are the best and are available for download from the www.analog.com
I like Texas Instrument. Knowledge base is very good, documents is also.
Re: Dsp prosessors
There is some document in ARM web. ARM has very good information about the their processors.
Dsp prosessors
It all depends on the type of DSP you are using. In general each manufacturer will have some documentation or datasheets regarding his type of processor.
s2c97
Re: Dsp prosessors
TI has a lot of AppNote explaining algorithm and including source code.It is very useful,you can take some AppNote to know how to apply DSP algorithm,even you don't use TI processor
Re: Dsp prosessors
thanx
There's a good ebook called Read Time digital Signal Processing by
Sen M Kuo, bob H.Lee. The DSP used in the book is TI's TMS320C5509. There are many examples in the book on using this DSP. Also gives an in-depth description of the architecture of the DSP. You can find the ebook in the link I've attached.
Re: Dsp prosessors
Both Analog Devices and TI have wide range of dsp processors and both have evaluation dev. tools which you can download or order and try out before spending any money.
If you need hardware, TI has some of the cheapest dsp starter kits including the full dev. tool (no timeouts unlike Analog's tools). Check out their website. For $295, you can get an OMAP starter kit with Monta Vista real time linux (the windows version is $5000). The possible downside (if you don't use linux) is the dev. tool is for linux.
