Hello!
I'm looking for a low cost color graphic LCD. Resolution 320x240(min), 480x320 (good), 640x480(max). It should have 8 or 16 color. All models what I found in net have controllers(e.g.SED). But I want to make my own controller in FPGA.
Item Specifications Unit
Screen size 10.9 (4.3” type) diagonal cm
Active area 95.04(H) 53.856(V) mm
480 272 pixel Pixel format
1Pixel =R+G+B dots
Pixel pitch 0.198(H) 0.198(V) mm
Pixel configuration R,G,B vertical stripes
Display mode Normally black
Unit outline dimensions 105.5(W) 67.2(H) 3.95(D) mm
Mass 50 g
Polarizer Surface treatment Clear hard coat
go to the page with the 240 x 320 tft color display , you will found my 3 projects
compiled with CCS C (source included).
The last drivers version is included in the 'Lunar Lander' game.
It will be easy for you to modify for all other type of language.
I use 16 bits colors for be faster.
And i have buy that screen mounted on controller board for only 40$.
Interresting toy PlatinumT ,
but will be better to get the screen with a control PCB for use it directly (like the
CAT32 DC-DC LED driver from techtoys)
Anyway , good choice for that resolution and price
Hello!
