Looking for information and codes on SPI interfacing
pepillo
Spain
SPI interface
Need information & code examples using SPI bus to drive any dsp/mcu/eeprom.
Thanks in advance
Re: SPI interface
This is a very good explanation regarding SPI interface (including mode 0 -3)
It's specific for AVR microcontrollers but you can learn a lot.
For code you must be more concise. As you read above the interconnection between two SPI devices always happens between a master device and a slave device. Which one you would like to be ? You mentioned "dsp/mcu/eeprom"
If 25LC640 is your concern then a briefly look into datasheet will give you some information about a slave:
https://ww1.microchip.com/downloads/en/devicedoc/21223g.pdf
Then you can look into two applications for the master behaviour:
One microcontroller with SPI by default
https://ww1.microchip.com/downloads/en/appnotes/00966a.pdf
and one where four GPIO are used for SPI
https://ww1.microchip.com/downloads/en/appnotes/01006a.pdf
Both of them using slave 25XXX SPI EEPROM series with nice snap shoots on logic analyzer screen.
The Microchip's funs on the forum will point out a better explanation for SPI.
Just because the SPI interface was established by Microchip, thus the best explanation of the interface must come from them.
    pepillo
Re: SPI interface
Thx a lot, silvio, great links that i will dive in soon. Hope to see ya around here often.
Re: SPI interface
pvinbox(at)yahoo.com said:
hai
pls check microchip application notes
there is lot of application notes are there.
bye
Smart answer.
If you're a really Microchip fun can you post a link from Microchip web site where it's clearly explained the ISP interface, but not specific to a device. It must be general reference. And definitely a link not kick and run.
BTW we are here to help each other and not earning or accumulating points.
You can even gain some friends.
But not with such kind of answers.
You know I've just pass through my favorite supermarket. And guess what ?
They just got in stock my lovely microcontroller.
Look at kachuisa's advice too. He just pass through my favorite supermarket, too
Oh, yeah I've just been there, I look around for a while, but I've forgot the shelf with your application note. Yeah, you better take a look too. And do not mind if you don't find it. And tomorrow is a day.
    pepillo
Re: SPI interface
First of all a huge laugh.. thnx silvio!!! :D
ok back on topic.
heheh still laughin.
SPI is a trademark of Motorola so if you are looking for the protocol description visit them.
What kind of controller are you using?
I think that SPI is the most easiest protocol there is.. much easier than i²c, 1Wire, CAN, or even standard serial data from any uart. the only pitfall is the idle state. and the phase of the clock signal, every chip has its own.
oh, i had some problems with spi, some chips are using the CS line to initiate a spi cycle. Read your datasheets and you'll find out.
for any questions.. please come again.
    pepillo
Re: SPI interface
i'm using 25lc640 to send a boot image to a dsp (VS1011 mp3 codec). i haven't got any controller, just the 25lc640 programmed with the boot image, the codec, and one mmc card with spi interface. i think the dsp requests the boot image on reset and then it works standalone. but anyway i need to understand the spi interface to achieve functionality.
Re: SPI interface
YES it's correct. My apologize for misleaded information. I don't know why I ever thought to Microchip as the developer of SPI bus.
P.S. I like AVR too and I'm joining to your opinion regarding PIC.
    pepillo
Re: SPI interface
i want use VS1011 mp3 codec & SD card on same SPi...
is this possible????????????/
link>>>>>>>>>???
Re: SPI interface
both those devices will have a chip select or device select pin. by controlling the logic state on that pin, u can connect them on same SPI.. u should disable one device while communicating with other..
Re: SPI interface
but many people says about loading problem???
what about this??
