Re: Rectifiers
That sounds like an interesting suggestion. But I did an online search and didn't find anything. Any help in the area of info location?
I have one other question, I'm a bit confused about something, I've never attempted to build/actually use a rectifier circuit before, I just used to seeing them in theory.
What I'm trying to do is create a rectifier in which the transistor switching is controlled by a DSP. Somewhat like the PWM switching of transistors in an inverter.
We're trying to convert ac-dc .....I know the typical diagram has transformer windings and then a load.
Will I be able to use the same circuit, since I'm using transistor switching?
