Looking for frequency counter schematic for microcontroller
igor
Junior Member level 1
slo
Hi
I want to build frequency counter with microcontrller 0 to 10,100,1000MHz(LCD or led display) with 8 digit display. Have anyone scheme with source code for microcontroller.
Thanks
led display frequency counter
Hi igor!
As I see, nobody has any suggestion for you, look on these constructions, maybe they are litlle bit old, but look what can you do...
You can take it from RA4NAL home page.
----- first (old) on at89c51 1Hz - 1000 MHz, 8 digits display: -----
russian languafe variant:
program:
----- second (new) 1Hz - 40 MHz 8 digits display on PIC16CE625: ----
russian description:
program:
additional prescaller:
You can combine these two schemes - take main part from second and input prescaller from first.
Best Wishes! klug.
pic frequency counter led 8 digit
chk this this is 4 digit
hwwp://www.pira.cz/
frequency meter+ Switchable -10.7 MHz intermediate frequency offset for use with receiver .
if any body help me about +10.7 Mhz if offset pls mail me
8-digit frequency counter schematics
great
thanks
tanveerriaz
frequency counter
Thanks for suggestion. I was made counter with 89C51. It has a best characteristic. Counter work original with quartz 6,144MHz , but I shall like change frequency to 10MHz. How can I change frequency oscilator? Instruction about this exsiste in instruction , but I dont now with which program I change hex source code for this microcontroller?
frequency counter 10.7mhz pic
Hi Igor!
You can open this file with any text editor.
I have opened your hex file and found string that you need:
:1001B00022082FD5FFFFFFFFFFFFFFFFFFFFFFFF1D
As you see, there are K1 = (08h) and K2 = (2FD5h) factors. You need to calculate them for your quartz frequency. Change these factors and calculate checksum (1Dh now) in the end of the string.
You will find hex file format and how to calculate checksum of string here:
Best Wishes! klug.
counter with nixie tubes
klag
this is a nice circuit
i like it
i like it
but i for many years used a nixie tube counter
my internal refresh rate is set to the same flicker as the refrsh
i find nixie more responsive
and the thing all lcd weened guys seem to lack when they use one they love it
i used one made by RCS it was 0 - 10 ghz 0- 500 mw max input
had a nice xtal oven running at 10 mhz and a divider made in ls logic with the usual SP / 10 chip
run on ten nixie tubes by lateral refresh
i very much like these counters
i will remake the schematic and cod e to a nixie tube version {if people can still find them they are much nicer on the eyes for the bench}
nothing more but thanks
www.webx.dk/oz2cpu/radios/counter.htm
:D
after looking at this i see there is space in the chip to add a button to also subtract 10.7 or add 10.7 or infact any programmable shift onto the freq as you requested
there fore build this one it loks fairly straight foward and looks like a winner covering the features you need
frequency meter 8 digit
Hi
I want to build one minute pulse generator with microcontrller. Have anyone scheme with source code for microcontroller.
Thanks
frequency meter source code
look at **broken link removed**
Enjoy!
frequency counter receiver if 10.7
hwwp://www.pira.cz/
HELLO MY PAL
after looking at the source and the schematic
then i am sorry but you need another i/o pin on the pic to be able to switch the shift into the counter assembler code.....
it is easy to do but you need to also add a pic 508 or something with a few i/o as a streatcher to the onboard pic you can then mode load the shift into the asm via a pin but there are non spare
oz2cpu
Iam interesting for counter the least 8 digit. Any other iI am not interesting.
frequency counter at89s51 6 digits
hi simbox :oops:
i am not a programmer and aboe file this file only hex file if u help me make 2 file for me 1. +10.7
and 2nd. -10.7 (when i need +- if i reporogram pic)
sorry for my bad english
thanks
rcs frequency counter
hi
i have build this:
h**p://www.efplus.com/techref/piclist/weedfreq.htm
there is only schematich and hex file
