Looking for a SMPS block diagram
x2pher
cebu, Philippines
Hi all,
can anybody help to provide complete block diagram of SMPS?
Appreciate if you include importance of each and how it affects/relationof the other circuits.
Thanks!
Re: SMPS block diagram
The switching converter converts the dc input power into a controllable output at a desired level. Either or both the input and output voltage/current are used for feedback.
Transformers are usually used to isolate the input and the output. The transformers are small in size due to high switching frequency used (~10-100kHz).
Below is the circuit of a buck converter. It shows how the control signal is generated.
[ref: Fundamentals of power electronics by Ericksson]
Finally, here are the switching waveforms of a buck converter
[ref: First course on power electronics by Rashid]
