Re: Regulator Issues
use a voltage pump made form a pair of transistors and a 555 timer as the oscillator using a split secondary L44 coil the primary driven with a 555 output via bootstraping driving the non tapped side of this lt
{low tension coil}
this way youll get the needed 180 degree shift easy from just a simple 555 youll get about 5amps this is safe for use at 2.5 amps
{ie not direct,,,,}
so national dont make a 2 amp pump just you can from a few devices
they might make a 2amp pump but 2amp absolute maximum so... it is totaly useless as it will just blow up
better make a rugged design 2.5X requirements
what a realy shitty answer flatulent
you need external transistors for above 1amp working current {2amp device} and national dont supply any
post us a number to view that fits the bill not just a half baked referance to a major supplier
