Mar 7, 2007 #1 M mwmmboy Full Member level 2 Joined May 18, 2001 Messages 134 Helped 8 Reputation 16 Reaction score 2 Trophy points 1,298 Activity points 979 I am looking for a pll with integrated VCO usable from 500 KHz to 1.5 MHz and working @ 1.8 Vdc. Any suggestion? Tx.
Mar 7, 2007 #2 N normaldist Junior Member level 3 Joined Aug 17, 2006 Messages 27 Helped 5 Reputation 10 Reaction score 1 Trophy points 1,283 Activity points 1,465 Re: PLL Try www.silabs.com Part Number Si4133W It should cover the band two different outputs. C
Mar 9, 2007 #3 M mwmmboy Full Member level 2 Joined May 18, 2001 Messages 134 Helped 8 Reputation 16 Reaction score 2 Trophy points 1,298 Activity points 979 Re: PLL Thanks, but the P/N you indicated is for frequencies in the GHz range... I need something working from 500 KHz to 1.5 KHz... Thanks again
