Looking for a 24V regulator
yigiter
Junior Member level 1
Istanbul,Turkey
28 v to 24v regulator
Hello,
I need a regulator that has the specifications below:
1)if Vin>25V Vout=24V
2)if Vin<25V Vout=Vin
if you could help it would be very appreciated.
Best regards,
Edit:
3)the load current is about 4 amp.
-Erkan
24V Regulator
What's the range of Vin?
    yigiter
Re: 24V Regulator
14<Vin<28V
So: for 14<Vin<25, Vout=Vin
for 25<Vin<28, Vout=24V
i have tried to do it using 7824 but it only works as
for Vin>27V, Vout=24V
Re: 24V Regulator
yigiter said:
14<Vin<28V
Yes. "7824" is a linear regulator. To work properly, it needs certain amount of voltage difference between input voltage and output voltage.
    yigiter
Re: 24V Regulator
is there a way to regulate Vin>25V to 24V?
Re: 24V Regulator
Wish the following link will help:
Pls update
    yigiter
Re: 24V Regulator
unfortunately,
i have searched it, too.
for 14<Vin<28, Vout=24 and I=4Amp; Maximum Switch Current is too high
isn't there a way as simple as 7824?
24V Regulator
Why did you say the maximum switch current is too 'high'? If I'm not mistaken, you need to supply a 4A load, right?
LM1084 is a low-dropout linear voltage regulator. In order to get 24V output, the minimum input voltage must be (24V + 1.3V) or above.
Pls update.
    yigiter
Re: 24V Regulator
if you click the "click to show why other parts were not found" button in;
you can see the your recommended IC(LM3478) is not suitable for me.
Re: 24V Regulator
i will research the LM1084 and feedback you.
Re: 24V Regulator
h**p://webench.national.com/servlet/SS?VinMin=14.0&VinMax=28&O1V=24&O1I=4&op_TA=30
Yes. You're right. I didn't note that the '5A' is the maximum current rating of the switch.
    yigiter
Re: 24V Regulator
i researched LM1084. it seems useful for me. i will get one and try. thank you for your helps.
Best regards,
-Erkan
