Hello,
I am running simulation at pspice for 400ms and it takes forever.
my circuit is big and my frequency is 200khz.
how can i reduce the simulation time so it takes couple of minutes instead of hours?
You could add initial bias point so that for each new simulation it would not require time to charge capacitors for example. You could also replace analog parts of the circuit which is not the focus of the current analysis.
Try reducing RELTOL= 0.005 as against default of 0.001. you can also tweak ABSTOL to 1n instead of 1p. This will loosen the tolerance and thus speed up simulation. however gain in terms of simulation time would be circuit specific. It also seems that your circuit has two very different time constant - a slow system may be 50 or 60Hz mains inputs supply and SMPS at 200KHz. Does it make sense to decouple these two for initial simulation thus faster simulation. At final stages connects these two system.
