Logic Symbol for and determine the size of ROM with 8x8 combinational multiplier
naavid
Newbie level 6
Can you please help me to draw a logic symbol for and determine the size of a ROM that realizes an 8x8 combinational multiplier???
Multiplexers are usually described as something like "8-to-1". What are you trying to describe with 8x8 multiplexer? Are you trying to make a cross-bar switch? Are you trying to make an 8-bit 8-to-1 multiplexer?
I can't give any meaningful answer unless I can tell what you are trying to accomplish.
The simple answer with any look-up table (a.ka. ROM) implementation is: Take all your "inputs" concatenate them together and stick them in as the address to a ROM with 2^address_width entries that has a data width of whatever your functions output width would be.
The request was for a "multiplier", not "multiplexer". An unsigned multiplier normally has the same number of output bits as the total number of input bits.
In this case it will have 16 input bits and 16 output bits. A 64K x 16 bits ROM is needed.
The logic symbol can be drawn in many ways.
