Logic Contention(s) Detected on data lines of LCD [Proteus Error]
armghan11
Member level 1
I am getting a logic contention detected error on proteus i am writing simple program using driver flexlcd16x4
My Code
#include <16F877A.h>
#fuses XT,NOWDT,NOPROTECT,NOLVP
#use delay(clock=4000000)
#include <lcd16x4.c>
void main()
   lcd_init();
   delay_ms(6);
   lcd_gotoxy(6,1);
   printf(lcd_putc,"Welcome");
   lcd_gotoxy(4,2);
   printf(lcd_putc,"To The World");
   lcd_gotoxy(8,3);
   printf(lcd_putc,"Of");
   lcd_gotoxy(6,4);
   printf(lcd_putc,"CSS C");
   while(1);
Driver Code 16x4
// Flex_LCD416.c
// These pins are for my Microchip PicDem2-Plus board,
// which I used to test this driver.
// An external 20x4 LCD is connected to these pins.
// Change these pins to match your own board's connections.
#define LCD_DB4   PIN_D4
#define LCD_DB5   PIN_D5
#define LCD_DB6   PIN_D6
#define LCD_DB7   PIN_D7
#define LCD_RS    PIN_E0
#define LCD_RW    PIN_E1
#define LCD_E     PIN_E2
// To prove that the driver can be used with random
// pins, I also tested it with these pins:
#define LCD_DB5   PIN_B1
#define LCD_DB6   PIN_C5
#define LCD_DB7   PIN_B5
#define LCD_RS    PIN_E2
#define LCD_RW    PIN_B2
#define LCD_E     PIN_D6
// If you want only a 6-pin interface to your LCD, then
// connect the R/W pin on the LCD to ground, and comment
// out the following line.  Doing so will save one PIC
// pin, but at the cost of losing the ability to read from
// the LCD.  It also makes the write time a little longer
// because a static delay must be used, instead of polling
// the LCD's busy bit.  Normally a 6-pin interface is only
// used if you are running out of PIC pins, and you need
// to use as few as possible for the LCD.
#define USE_RW_PIN   1
// These are the line addresses for 16x4 Hitach LM041L
#define LCD_LINE_1_ADDRESS 0x80
#define LCD_LINE_2_ADDRESS 0xC0
#define LCD_LINE_3_ADDRESS 0x90
#define LCD_LINE_4_ADDRESS 0xD0
// These are the line addresses for LCD's which use
// the Hitachi HD66712U controller chip.
#define LCD_LINE_1_ADDRESS 0x00
#define LCD_LINE_2_ADDRESS 0x20
#define LCD_LINE_3_ADDRESS 0x40
#define LCD_LINE_4_ADDRESS 0x60
#define lcd_type 2   // 0=5x7, 1=5x10, 2=2 lines(or more)
int8 lcd_line;
int8 const LCD_INIT_STRING[4] =
 0x20 | (lcd_type << 2),  // Set mode: 4-bit, 2+ lines, 5x8 dots
 0xc,                     // Display on
 1,                       // Clear display
 6                        // Increment cursor
void lcd_send_nibble(int8 nibble)
// Note:  !! converts an integer expression
// to a boolean (1 or 0).
 output_bit(LCD_DB4, !!(nibble & 1));
 output_bit(LCD_DB5, !!(nibble & 2));
 output_bit(LCD_DB6, !!(nibble & 4));
 output_bit(LCD_DB7, !!(nibble & 8));
 delay_cycles(1);
 output_high(LCD_E);
 delay_us(2);
 output_low(LCD_E);
// This sub-routine is only called by lcd_read_byte().
// It's not a stand-alone routine.  For example, the
// R/W signal is set high by lcd_read_byte() before
// this routine is called.
#ifdef USE_RW_PIN
int8 lcd_read_nibble(void)
int8 retval;
// Create bit variables so that we can easily set
// individual bits in the retval variable.
#bit retval_0 = retval.0
#bit retval_1 = retval.1
#bit retval_2 = retval.2
#bit retval_3 = retval.3
retval = 0;
output_high(LCD_E);
delay_us(1);
retval_0 = input(LCD_DB4);
retval_1 = input(LCD_DB5);
retval_2 = input(LCD_DB6);
retval_3 = input(LCD_DB7);
output_low(LCD_E);
delay_us(1);
return(retval);
#endif
// Read a byte from the LCD and return it.
#ifdef USE_RW_PIN
int8 lcd_read_byte(void)
int8 low;
int8 high;
output_high(LCD_RW);
delay_cycles(1);
high = lcd_read_nibble();
low = lcd_read_nibble();
return( (high<<4) | low);
#endif
// Send a byte to the LCD.
void lcd_send_byte(int8 address, int8 n)
output_low(LCD_RS);
#ifdef USE_RW_PIN
while(bit_test(lcd_read_byte(),7)) ;
#else
delay_us(60);
#endif
if(address)
   output_high(LCD_RS);
else
   output_low(LCD_RS);
 delay_cycles(1);
#ifdef USE_RW_PIN
output_low(LCD_RW);
delay_cycles(1);
#endif
output_low(LCD_E);
lcd_send_nibble(n >> 4);
lcd_send_nibble(n & 0xf);
void lcd_init(void)
int8 i;
lcd_line = 1;
output_low(LCD_RS);
#ifdef USE_RW_PIN
output_low(LCD_RW);
#endif
output_low(LCD_E);
// Some LCDs require 15 ms minimum delay after
// power-up.  Others require 30 ms.  I'm going
// to set it to 35 ms, so it should work with
// all of them.
delay_ms(35);
for(i=0 ;i < 3; i++)
    lcd_send_nibble(0x03);
    delay_ms(5);
lcd_send_nibble(0x02);
for(i=0; i < sizeof(LCD_INIT_STRING); i++)
    lcd_send_byte(0, LCD_INIT_STRING[i]);
    // If the R/W signal is not used, then
    // the busy bit can't be polled.  One of
    // the init commands takes longer than
    // the hard-coded delay of 50 us, so in
    // that case, lets just do a 5 ms delay
    // after all four of them.
    #ifndef USE_RW_PIN
    delay_ms(5);
    #endif
void lcd_gotoxy(int8 x, int8 y)
int8 address;
switch(y)
   case 1:
     address = LCD_LINE_1_ADDRESS;
     break;
   case 2:
     address = LCD_LINE_2_ADDRESS;
     break;
   case 3:
     address = LCD_LINE_3_ADDRESS;
     break;
   case 4:
     address = LCD_LINE_4_ADDRESS;
     break;
   default:
     break;
address += x-1;
lcd_send_byte(0, 0x80 | address);
void lcd_putc(char c)
 switch(c)
    case '\f':
      lcd_send_byte(0,1);
      lcd_line = 1;
      delay_ms(2);
      break;
    case '\n':
       lcd_gotoxy(1, ++lcd_line);
       break;
    case '\b':
       lcd_send_byte(0,0x10);
       break;
    default:
       lcd_send_byte(1,c);
       break;
#ifdef USE_RW_PIN
char lcd_getc(int8 x, int8 y)
char value;
lcd_gotoxy(x,y);
// Wait until busy flag is low.
while(bit_test(lcd_read_byte(),7));
value = lcd_read_byte();
output_low(LCD_RS);
return(value);
#endif
This error occurs when in proteus Nets so wired as to be likely to result in contentions - i.e. two outputs trying to drive in different directions, resulting in a large flow of current.
So check your connection in proteus. or attach your proteus file.
here is the attachment
  • 16x4 LCD.rar
While you read any data from the LCD, have to change temporarily the direction of the used pins (RD4...7).
Use this Driver Code 16x4
// Flex_LCD416.c
int8 lcd_line;
 0xc,                     // Display on
 1,                       // Clear display
 delay_cycles(1);
 output_high(LCD_E);
 delay_us(2);
 output_low(LCD_E);
#ifdef USE_RW_PIN
int8 retval;
retval = 0;
input(LCD_DB4);
input(LCD_DB5);
input(LCD_DB6);
input(LCD_DB7);
output_high(LCD_E);
delay_us(1);
output_low(LCD_E);
delay_us(1);
return(retval);
#endif
#ifdef USE_RW_PIN
int8 low;
int8 high;
delay_cycles(1);
#endif
output_low(LCD_RS);
#ifdef USE_RW_PIN
#else
delay_us(60);
#endif
if(address)
else
   output_low(LCD_RS);
 delay_cycles(1);
#ifdef USE_RW_PIN
output_low(LCD_RW);
delay_cycles(1);
#endif
output_low(LCD_E);
void lcd_init(void)
int8 i;
lcd_line = 1;
output_low(LCD_RS);
#ifdef USE_RW_PIN
output_low(LCD_RW);
#endif
output_low(LCD_E);
// all of them.
delay_ms(35);
    delay_ms(5);
    #ifndef USE_RW_PIN
    delay_ms(5);
    #endif
int8 address;
switch(y)
   case 1:
     break;
   case 2:
     break;
   case 3:
     break;
   case 4:
     break;
   default:
     break;
address += x-1;
 switch(c)
    case '\f':
      lcd_send_byte(0,1);
      lcd_line = 1;
      delay_ms(2);
      break;
    case '\n':
       break;
    case '\b':
       break;
    default:
       lcd_send_byte(1,c);
       break;
#ifdef USE_RW_PIN
char value;
lcd_gotoxy(x,y);
output_low(LCD_RS);
return(value);
#endif
// Flex_LCD416.c
int8 lcd_line;
 0xc,                     // Display on
 1,                       // Clear display
 delay_cycles(1);
 output_high(LCD_E);
 delay_us(2);
 output_low(LCD_E);
#ifdef USE_RW_PIN
int8 retval;
retval = 0;
input(LCD_DB4);
input(LCD_DB5);
input(LCD_DB6);
input(LCD_DB7);
output_high(LCD_E);
delay_us(1);
output_low(LCD_E);
delay_us(1);
return(retval);
#endif
#ifdef USE_RW_PIN
int8 low;
int8 high;
delay_cycles(1);
#endif
output_low(LCD_RS);
#ifdef USE_RW_PIN
#else
delay_us(60);
#endif
if(address)
else
   output_low(LCD_RS);
 delay_cycles(1);
#ifdef USE_RW_PIN
output_low(LCD_RW);
delay_cycles(1);
#endif
output_low(LCD_E);
void lcd_init(void)
int8 i;
lcd_line = 1;
output_low(LCD_RS);
#ifdef USE_RW_PIN
output_low(LCD_RW);
#endif
output_low(LCD_E);
// all of them.
delay_ms(35);
    delay_ms(5);
    #ifndef USE_RW_PIN
    delay_ms(5);
    #endif
int8 address;
switch(y)
   case 1:
     break;
   case 2:
     break;
   case 3:
     break;
   case 4:
     break;
   default:
     break;
address += x-1;
 switch(c)
    case '\f':
      lcd_send_byte(0,1);
      lcd_line = 1;
      delay_ms(2);
      break;
    case '\n':
       break;
    case '\b':
       break;
    default:
       lcd_send_byte(1,c);
       break;
#ifdef USE_RW_PIN
char value;
lcd_gotoxy(x,y);
output_low(LCD_RS);
return(value);
#endif
yes its working fine now :) thanks
please tell me what was i doing wrong? i would like to know
Since you are using R/W pin, the driver code read the LCD busy bit while(bit_test(lcd_read_byte(),7)); before sending data. the direction of (LCD_DB4 - 7) microcontroller is set to output. The direction of LCD data pins are also output in read mode. - i.e. two outputs trying to drive in different directions, resulting in a large flow of current and causing Logic Contention Detected.
I just changed the direction of controller pins to inputs before enabling LCD_E in lcd_read_byte() function. input(LCD_DB4); input(LCD_DB5); input(LCD_DB6);input(LCD_DB7);
Note: CCS compiler automatically change the direction to input or output with input() and output_Low/high statements provided that fast_IO directive is not used.
