Hello, I just bought a used LOGIK LOG19WHD17. I was told it has Freeview but using the controls on top of the TV and the remote, there's no option to set up Freeview.
According to the specifications it has Freeview built in.
Usually on models like that there is a menu option to select the input mode. "TV" refers to analog transmissions, you have to set it to "DTV" to pick up digital Freeview transmissions. I'm not sure where you are but note that Freeview will only work in the UK. Digital reception in other places will still work but you need an external box and a connection through a HDMI cable.
