Local Skew & Global Skew
handsome
Junior Member level 3
local skew
locak skew: skew between the launch reg's clock and the capture reg's clock
global skew: the max skew in the clock tree
If any error,please correct me
    kumar_eee
kapil_vlsi1
Member level 2
local skew global skew
Local Skew : Source and Destination flop insertion delay is called local skew.
Global Skew : Max insertion delay minus Min Insertion Delay is called Global Skew.
    kumar_eee
arjun1110
Bangalore,India
local skew and global skew
Hi Kapil,
What is the significance of Global skew.
Regards,
    V
kapil_vlsi1
Member level 2
what is global skew
Significance of Global Skew is it finds out the delay of the clock tree in such a way that it removes the setup violation as well as Hold violation. In this context, we have to use skew balancing to get the required slack.
Hope this helps...
    kumar_eee
arjun1110
Bangalore,India
why global skew?
Hi Kapali,
I am not clear with above statement? How global skew removes the setup and hold violation. Please will elobarate.
Regards
raju3295
Full Member level 4
skew balancing
good point to discuss, generally even a cts algoritham quality is estimated on the basis of the global skew, but i dont get why it is of importance, if a local skew b'wen adjusant registers is small that will help in timing
zhipeng
Member level 1
USA
No idea why global skew is of any importance at all...
Local skew should be generally minimized, or sometimes could be increased for a too slow path between two registers. And skew between registers driving synchronous output should be generally minimized? Is that correct? Is there any situation where global skew matters at all?
    kumar_eee
rca
Advanced Member level 5
Marin
the EDA speaks also of the useful/local/global skews
useful is as you call the local skew
the local skew is the skew in a sub-group
global skew is the skew that include all clocks pins.
wkong_zhu
Full Member level 3
How to report local skew?
It seems that Primetime can only report global skew.
rca
Marin
that's right, PrimeTime can not repot local/skew skew.
But the most important is the setup/hold.... checks passed.
the skew/clock reports some info on the clock tree quality, that's all.
    kumar_eee
semi_jl
Member level 4
In my opinion, if you are working on a chip (flat design), the global skew is not important if you can close timing, especially for hold.
Buf if you are working on a block and it is a full chip clock domain, the global skew will make effect at full chip timing for global clock balance. You need to meet the latency &. skew requirements for chip timing close.
