Local parameter value will be used in Cadence Spectre
pancho_hideboo
Advanced Member level 5
Real Homeless
When I create netlist by skill function of "createNetlist(?recreateAll t, ?display t)" in Cadence IC6.1.7, I get following netlist.
However Cadence Spectre show following warning.
I want to pass nf=4 for "Rec0" and "Rec1" hierarchally.
What value is applied as nf for "Rec0" and "Rec1" hierarchally ?
If I create netlist from ADE, I get following netlist.
Cadence Spectre does not say warning of "Local parameter value will be used." for this netlist.
How can I create same netlist by "createNetlist(?recreateAll t, ?display t)" ?
If I create netlist from ADE, ...
Can you generate the ADE logFile (OCEAN ?). Perhaps you can find a hint therein?
If nf value is not set in ADE, netlist is same as first one even by creating it from ADE.
