Loading program with 80x51 family on ACEX1K
syntronik
Newbie level 5
Migrations to ACEX1K
Hello
I have worked a long time whith MAX7000S family, now I need to change to ACEX1K, I have see the possibility of use i/o voltage qt 5 volts, and I whant to load the program, not whith serial eeprom but whith 80x51 family, somebody have some applycations for help me, the manuals not have more informations, only somes article and not more.
Regards
Maurizio
clmelettronica.com
Re: Migrations to ACEX1K
Do u have 8051 on ur board ??? or is there a chance of change in ur logic later ??
i think going with serial Eprom is better... u can go with EPC2 series also... or download directly from byteblaster or master blaster..
I have a 80c32 on board, but the memory of EPK50-208 is to large, better use EPC16 exepencive but OK, I have also found the documentation on Altera Site. You work whith 80X51 family? if yes we can interchange somes suggestions
regards
Maurizio
No i never done that... but was planning to do that....
I used PS config and JTAG config to load my program..
what about u ?
I use ByteBlasterMV, I just finish to nigth to develop in verilog, the control position, for 4 motor ,
and I have select the SPP configuration
Regards
Maurizio
