to Madhukar
1)For noise matching ,how to noise matching in Spectra RF or ADS .
2)When the circuits is for the noise matching ,the S11 may be larger -10dB, which is the request commonly.
thank you
Hi!
Using ADS is very simple to do that.
1)To get the input matching network for NFmin:
a) You just have to extract NFmin of the device vs Vbias for the working frequency.
b) Next with NFopt reflection coefficient uses smith chart utility from the ADS palette to generate the input matching network automatically.
c) Then choose the right input matching network to generate NFopt reflection coefficient to get NFmin.
d) Build ADS... to put the input impedance matching on schematic... and... you are done!
If you have any doubts... reply...
2) -10 dB it's okay! If you have a filter or an antenna behind the LNA in the receiver chain and coefficient input reflection, S11; with more than -10 dB can generate distortion on filter characteristics.
Normally you have tradeoff between NF, Power and S11. So choosing the right device size and bias is important.
