LM7815 capacitor value
vinu gopalakrishnan
Member level 1
Member level 1
calicut
Hey friends,..Can i use 470nf in place of the 330nf capacitor in this circuit???
Please tell me what is the use of these capacitors..
Input capacitors is to reduce the ripple voltage amplitude seen at the input
of the module.
As the output voltage is sensed across both the filter and load impedance,
The impedance of the output capacitance affects the damping of the output filter and has a major affect on
the transient response of the supply.
https://www.ti.com/lit/an/slta055/slta055.pdf
I hope this will helps you..
so small ceramic capacitors will be enough ,right?
We can use both capacitors like aluminium ,ceramic capacitors .
Ceramic capacitors with high stability and low losses for resonant circuit application.
You can use larger value capacitors without any problems, so it's totally acceptable to use a 470nF instead of 330nF.
That's a 0.047uF (microfarad) or 47nF.
