cgchas
Member level 3
Regarding the attached shunt regulator schematic from the LM723 datasheet: **broken link removed**
I want to be able to regulate a 4.8A load from 2V to 12V (give or take a few tenths of a volt).
I am aware of the poor efficiency associated with shunt regulators, but I would like to use an existing +12VDC supply as the input.
I am considering a 2N3055 as the external pass transistor with R4 as 2.4 ohms. (60 watts)
Could such a configuration (or similar) work?
Thank you for reading and for any suggestions.
Charles
Charles
