sac1991
I have designed a buck converter 48V-12V 1A using Webench Design Tool. Every PCB behaves same way. Initial 30s output becomes 12V then it starts to show weird ripple in the output voltage. It would be clear from the scope screenshot I have attached. After reading the datasheet again I have added a ramp resistor between Vcc and Cramp as per datasheet calculation. But still it shows no improvement.
