dabby21
- Joined
- Aug 8, 2011
- Messages
- 114
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,296
- Location
- Philippines
- Activity points
- 2,232
sirs,
good day,
im working a simulation on LM35 through pic and output the results in LCD.
upon researching, i have come up the above code, outputting the string temperature and character to the LCD was good, but when i try to change the result of LM35 in protues, it does not change the result on the LCD.\
heres my simulation on proteus sirs. thanks in advance
good day,
// LCD module connections
sbit LCD_RS at RB2_bit;
sbit LCD_EN at RB3_bit;
sbit LCD_D4 at RB4_bit;
sbit LCD_D5 at RB5_bit;
sbit LCD_D6 at RB6_bit;
sbit LCD_D7 at RB7_bit;
sbit LCD_RS_Direction at TRISB2_bit;
sbit LCD_EN_Direction at TRISB3_bit;
sbit LCD_D4_Direction at TRISB4_bit;
sbit LCD_D5_Direction at TRISB5_bit;
sbit LCD_D6_Direction at TRISB6_bit;
sbit LCD_D7_Direction at TRISB7_bit;
// End LCD module connections
float temp;
char i,txt[15];
unsigned int temp_res;
unsigned int quanta=0.488;
void Move_Delay() { // Function used for text moving
Delay_ms(500); // You can change the moving speed here
void main(){
ADCON1 = 0x0E;
ADCON0 = 0x00; // Set PORTA.0 To analog And all others digital
ADCON2 = 0x8A; // Set PORTA analog And right justify result
TRISA = 0xFF;
TRISB = 0x00;
PORTB = 0x00;
LATB = 0x00;
Lcd_Init(); // Initialize LCD
Lcd_Cmd(_LCD_CLEAR); // Clear display
Lcd_Cmd(_LCD_CURSOR_OFF); // Cursor off
Lcd_Out(1, 1, "Temperature :");
Lcd_Chr(2,8,223); // Different LCD displays have different
// char code for degree
Lcd_Chr(2,9,'C'); // Display "C" for Celsius
ADC_Init(); // Initialize ADC
do{
temp_res = ADC_Read(0);
temp= temp_res * quanta;
FloatToStr(temp, txt); // Convert temperature to string
Lcd_Out(2,3,txt);
Delay_Ms(300);
} while(1);
/* Lcd_Cmd(_LCD_CLEAR); // Clear display
Lcd_Out(1,6,txt3); // Write text in first row
Lcd_Out(2,6,txt4); // Write text in second row
Delay_ms(2000);
Lcd_Out(1,1,txt1); // Write text in first row
Lcd_Out(2,5,txt2); // Write text in second row
Delay_ms(2000);
// Moving text
for(i=0; i<4; i++) { // Move text to the right 4 times
Lcd_Cmd(_LCD_SHIFT_RIGHT);
Move_Delay();
while(1) { // Endless loop
for(i=0; i<8; i++) { // Move text to the left 7 times
Lcd_Cmd(_LCD_SHIFT_LEFT);
Move_Delay();
for(i=0; i<8; i++) { // Move text to the right 7 times
Move_Delay();
