Hello
I have an older design in front of me and I'm thinking about modernization and shrinking.
The original design looks like this.
DC/DC Stepdown 3A
LM2576HV-Adj make output DC voltage for
RF Power Amplifier with RF power MOSFET amplifier which creates RF power sinus over 10MHz.
Feedback for LM2576 is from output RF Amplifier , which creates from RF DC 1,23V for LM2576HV Adj.
It all works surprisingly well, and it's actually simple.
52kHz converter but requires large electrolytic capacitors, big coil and I need somewhat higher power.
My idea.
use Synchronous Step-Down DC/DC
LM76003
this work on 500kHz , suffices with SMD ceramic capacitor, small coil and is in 6x4mm WQFN package,FB is 1.006V.
On the first look, it looks like it's easy to modify FB and it should work,
On second look, 10 times higher frequency, another structure of internal loopback etc.
I can not judge it and so I want to ask more experienced will it work?
with any problems I can count on?
Eventually with any problems I can count on?
Second question.
My device is RF and it is closed and is not cooled by the flowing air
LM76003 have high efficiency, but high switching speed and some conductivity losses I thing need take heat away.
I thing WQFN is on TOP PCB, and button PCB is flexibly pressed against the metal wrapper through which it cool. it is used for such a gray flexible heat-conducting rubber, I do not know how it is named and who sells it?
