Linux kernel build problem in Xilinx ML605
FuzzySNR
Member level 2
Member level 2
Hi all,
While I am trying to build the Xilinx Linux kernel for the ML605 board, I bump into the following error messages (I am on Ubuntu 12.04LTS):
cc1: error: unrecognized command line option ‘-mno-xl-soft-div’
cc1: error: unrecognized command line option ‘-mxl-barrel-shift’
cc1: error: unrecognized command line option ‘-mxl-pattern-compare’
cc1: error: unrecognized command line option ‘-mxl-multiply-high’
cc1: error: unrecognized command line option ‘-mno-xl-soft-mul’
I have git cloned the latest kernel sources from Xilinx git (git clone git://git.xilinx.com/linux-xlnx.git master) and then I proceeded as follows:
cp microblaze_v2.0_le/initramfs_minimal_le.cpio.gz linux-2.6-microblaze
cp sdk/device-tree_bsp_0/microblaze_0/libsrc/device-tree_v0_00_x/xilinx.dts linux
xlnx/arch/microblaze/boot/dts/
make ARCH=microblaze mrproper
make ARCH=microblaze mmu_defconfig (xilinx_mmu_deconfig doesn't exist!)
make ARCH=microblaze xconfig (where I changed the MB version and kernel base address to match my .MHS and set barell shifter to 1)
make ARCH=microblaze simpleImage.xilinx
Really stuck here, any help?
Looks like you're using the wrong compiler. If so, you should set up your environment as per whatever instructions are in the documentation that you have and I don't. ;-)
Well, the installed version was gcc-4.6 (4.6.3). Tried to switch to gcc-4.7, but sadly I get same errors.
delk@Darwin:~/Desktop/LinuxForMicroBlaze-ML605/xps/linux-xlnx$ make ARCH=microblaze simpleImage.xilinx
CHK include/config/kernel.release
CHK include/generated/uapi/linux/version.h
CHK include/generated/utsrelease.h
CC kernel/bounds.s
gcc: error: unrecognized command line option ‘-mxl-barrel-shift’
gcc: error: unrecognized command line option ‘-mxl-multiply-high’
gcc: error: unrecognized command line option ‘-mno-xl-soft-mul’
make[1]: *** [kernel/bounds.s] Error 1
make: *** [prepare0] Error 2
Quoting from README file:
COMPILING the kernel:
- Make sure you have at least gcc 3.2 available.
So, no much of a help here.
That was indeed what I was implying, since you wouldn't believe the amount of n00bness one comes across on this part of the forum. ;-)
So you are 100% sure that when you do a make, that it actually uses the correct compiler? Because those error messages seem to indicate it's using a compiler that doesn't understand the magic xilinx flags.
Well...its somewhat complicated...rather embarrassing...:oops: but to cut a long story short, my microblaze-gnu directory was empty, since git clone git://git.xilinx.com/microblaze-gnu.git doesn't exist any more or...see for yourself:
delk@Darwin:~$ git clone git://git.xilinx.com/microblaze-gnu.git
Cloning into 'microblaze-gnu'...
fatal: unable to connect to git.xilinx.com:
git.xilinx.com[0: 149.199.60.191]: errno=Connection timed out
Therefore even though I've exported my path variables...obviously they pointed to absolute nothing!
Any ways, I cloned this repo git://git.xilinx.com/xldk/microblaze_v2.0_le.git , according to the Xilinx WiKi https://xilinx.wikidot.com/mb-gnu-tools and even though I managed to pass on the previous errors, the build fails again with:
arch/microblaze/kernel/head.S: Assembler messages:
arch/microblaze/kernel/head.S:68: Error: register expected, but saw 'rslr,r'
arch/microblaze/kernel/head.S:68: Error: register expected, but saw 'slr,r0'
arch/microblaze/kernel/head.S:68: Fatal error: invalid value for special purpose register
make[1]: *** [arch/microblaze/kernel/head.o] Error 1
make: *** [arch/microblaze/kernel] Error 2
What the heck is that?
How? What sorcery is this? Did you do a clone just now or did you already have one lying around? Because that is exactly the same host as the previous one that failed. Case in point, I just tried both your listed git repos, and they both fail. Which makes sense (to me) in the sense that if the first one goes *urgle* then the second one should also go *urgle*. Both are git://git.xilinx.com/<whatever> as in same host, same port. And over here they both fail with a connection timeout just like you showed.
Anyways....
That is progress! ;-) At least now you are past the first stage. Could you do a make clean and run that make again and post all output? That might give some context. All this tells me is that the assembler didn't feel like it at some point. It usually helps to see what point that is.
Weird isn't? My case, first repo times out as posted but the 2nd ones clones normally! I've got no clue...kinda chaotic repo :!:
I'll try to make clean even -mrproper and I'll post back the results.
Nope...I get the same errors after make clean and build.
delk@Darwin:~/Desktop/LinuxForMicroBlaze-ML605/xps/linux-xlnx$ make ARCH=microblaze clean
CLEAN .
CLEAN usr
CLEAN .tmp_versions
HOSTCC scripts/basic/fixdep
CC kernel/bounds.s
GEN include/generated/bounds.h
CC arch/microblaze/kernel/asm-offsets.s
GEN include/generated/asm-offsets.h
CALL scripts/checksyscalls.sh
HOSTCC scripts/dtc/checks.o
HOSTCC scripts/dtc/data.o
HOSTCC scripts/dtc/dtc-lexer.lex.o
HOSTCC scripts/dtc/dtc-parser.tab.o
HOSTCC scripts/dtc/dtc.o
HOSTCC scripts/dtc/flattree.o
HOSTCC scripts/dtc/fstree.o
HOSTCC scripts/dtc/livetree.o
HOSTCC scripts/dtc/srcpos.o
HOSTCC scripts/dtc/treesource.o
HOSTCC scripts/dtc/util.o
HOSTLD scripts/dtc/dtc
HOSTCC scripts/genksyms/genksyms.o
HOSTCC scripts/genksyms/lex.lex.o
HOSTCC scripts/genksyms/parse.tab.o
HOSTLD scripts/genksyms/genksyms
CC scripts/mod/empty.o
WARNING: could not find objcopy version or version is less than 2.17.
Local function references are disabled.
HOSTCC scripts/mod/mk_elfconfig
MKELF scripts/mod/elfconfig.h
CC scripts/mod/devicetable-offsets.s
GEN scripts/mod/devicetable-offsets.h
HOSTCC scripts/mod/file2alias.o
HOSTCC scripts/mod/modpost.o
HOSTCC scripts/mod/sumversion.o
HOSTLD scripts/mod/modpost
HOSTCC scripts/selinux/genheaders/genheaders
HOSTCC scripts/selinux/mdp/mdp
HOSTCC scripts/kallsyms
HOSTCC scripts/conmakehash
HOSTCC scripts/sortextable
CC init/main.o
CHK include/generated/compile.h
CC init/version.o
CC init/do_mounts.o
CC init/do_mounts_rd.o
CC init/do_mounts_initrd.o
CC init/do_mounts_md.o
LD init/mounts.o
CC init/initramfs.o
CC init/calibrate.o
CC init/init_task.o
LD init/built-in.o
HOSTCC usr/gen_init_cpio
GEN usr/initramfs_data.cpio
AS usr/initramfs_data.o
LD usr/built-in.o
CC arch/microblaze/kernel/dma.o
CC arch/microblaze/kernel/exceptions.o
AS arch/microblaze/kernel/hw_exception_handler.o
CC arch/microblaze/kernel/intc.o
CC arch/microblaze/kernel/irq.o
CC arch/microblaze/kernel/process.o
CC arch/microblaze/kernel/prom.o
CC arch/microblaze/kernel/prom_parse.o
CC arch/microblaze/kernel/ptrace.o
CC arch/microblaze/kernel/reset.o
CC arch/microblaze/kernel/setup.o
CC arch/microblaze/kernel/signal.o
CC arch/microblaze/kernel/sys_microblaze.o
CC arch/microblaze/kernel/timer.o
CC arch/microblaze/kernel/traps.o
CC arch/microblaze/kernel/unwind.o
CC arch/microblaze/kernel/cpu/cache.o
CC arch/microblaze/kernel/cpu/cpuinfo.o
CC arch/microblaze/kernel/cpu/cpuinfo-pvr-full.o
CC arch/microblaze/kernel/cpu/cpuinfo-static.o
CC arch/microblaze/kernel/cpu/mb.o
CC arch/microblaze/kernel/cpu/pvr.o
LD arch/microblaze/kernel/cpu/built-in.o
CC arch/microblaze/kernel/early_printk.o
CC arch/microblaze/kernel/microblaze_ksyms.o
CC arch/microblaze/kernel/module.o
AS arch/microblaze/kernel/misc.o
CC arch/microblaze/kernel/stacktrace.o
CC arch/microblaze/kernel/ftrace.o
AS arch/microblaze/kernel/mcount.o
CC arch/microblaze/kernel/kgdb.o
AS arch/microblaze/kernel/entry.o
LD arch/microblaze/kernel/built-in.o
AS arch/microblaze/kernel/head.o
Seems to be a microblaze little versus big endian problem.
Read more about it here:
http://forums.xilinx.com/t5/Embedded-Linux/Microblaze-V2-0-compile-problem/td-p/196840
http://arhata.blogspot.nl/p/linux-on-fpga-board-bringup-2.html
So basically, the kernel version you are trying to compile doesn't play nice with your current toolchain version. I don't know the answer, but the question you want answered is "which kernel versions play nicely with which tool chain versions?".
And we all know that checking out the latest whateveritis that happens to be in a git repo is the best way to get verifiable build results. ;-) Isn't there maybe a .zip or a repo tag that you can checkout as "known to build with toolchain such-n-such"?
This thing turns out to be a nightmare...First of all I should thank you for your time trying to help me out, really appreciate it! Your last post is pretty much what I've thought meself, little and big endian, therefore I went ahead and cloned the big endian GNU toolchain. Make clean, fingers crossed....nada, nil, build fails at the same stage with exactly the same errors! Then I finally managed to git clone this repo git://git.xilinx.com/microblaze-gnu.git (remember is the one that timed out a couple days ago...), hoping...but it fails again, no matter what I set the endian to, little or big!
I am running out of options here...really driving me crazy!
The "slr" (stack low register) seems to be for optional hardware assisted stack protection.
It seems that files assuming existing "slr" are used for the build, but the assembler is not configured for a MicroBlaze with this register.
I see. Any ideas how to "adjust" the microblaze configuration or the make .config file to get past these errors?
OK, I had some progress at last...
I cloned version tagged xilinx_v3.0, configured it according to my .dts file, used microblaze_v2.0_le toolchain and finally managed to build the kernel image successfully!
Now, the bad news...I connect and download the kernel to microblaze but when I issue run at the xmd, the boot process (I use CuteCOM for monitoring RS232) displays the following messages and then freezes:
early_printk_console is enabled at 0x40600000
Ramdisk addr 0x00000003, Compiled-in FDT at 0xc02888c8
Any ideas?
yay. :)
Could you include the explicit command you used to check this out? There are bound to be more victims of this.
Any ideas?
Nope. But you could check 2 things. 1) sudden change of baud rate for whatever reason ... not very likely, but I've seen stupider stuff. 2) include a chipscope to check certain registers. Program counters are always a fun candidate.
Common people...Am dying here!!!
Pretty talkative (well, typative) for a soon to be dead guy. :p
Additionally, we're all dying. The trick is to keep the dying rate on the low side.
OK,
for the Kernel:
git clone https://github.com/Xilinx/linux-xlnx.git
git checkout xilinx_v3.0
for the GNU toolchain:
git clone git://git.xilinx.com/xldk/microblaze_v2.0_le.git
for the device-tree:
git clone git://git.xilinx.com/device-tree.git
git checkout xilinx-3.0-kernel
I've got no idea how to check for the first one. As for the 2nd, I was trying to avoid inserting chipscope...too much of a hassle...I'll give it a go though if there are no other obvious things to try first.
Ooops...auto correction typo! C'mon...:oops: Common people, Pulp, brilliant song! :grin:
If it is of any help I could post my .mhs, .dts, .config, etc files.
OK,
for the Kernel:
Thanks. :)
Checking baud rate? Just put a scope or logic analyzer on the TX pin should do it.. Basically I was just cautioning against making the assumption that "no data received" == "microblaze stopped sending data". As for chipscope being a hassle ... well that's relative. If you have spent more than an hour mucking about I'd say some extra debugging resources are in order. Adding a chipscope instance and getting some meaningfull data is definitely done in less than an hour. ;)
Yes please. :)
Oohh, I see, yes I could do that. I thought you meant to check SW wise.
I've fiddled with chipscope couple of times, so I might as well try it.
Thinking twice, since I've included an MDM module in MB, I could use mb-gdb to dump register contents (saves me from inserting chipscope).
Follows my .mhs, .dts, .config in this order (beware, lengthy...!) :
# Created by Base System Builder Wizard for Xilinx EDK 14.3 Build EDK_P.40xd
# Wed Jan 29 18:26:38 2014
# Target Board:  xilinx.com ml605 Rev D
# Family:    virtex6
# Device:    xc6vlx240t
# Package:   ff1156
# Speed Grade:  -1
 PARAMETER VERSION = 2.1.0
 PORT ddr_memory_we_n = ddr_memory_we_n, DIR = O
 PORT ddr_memory_ras_n = ddr_memory_ras_n, DIR = O
 PORT ddr_memory_odt = ddr_memory_odt, DIR = O
 PORT ddr_memory_dqs_n = ddr_memory_dqs_n, DIR = IO, VEC = [0:0]
 PORT ddr_memory_dqs = ddr_memory_dqs, DIR = IO, VEC = [0:0]
 PORT ddr_memory_dq = ddr_memory_dq, DIR = IO, VEC = [7:0]
 PORT ddr_memory_dm = ddr_memory_dm, DIR = O, VEC = [0:0]
 PORT ddr_memory_ddr3_rst = ddr_memory_ddr3_rst, DIR = O
 PORT ddr_memory_cs_n = ddr_memory_cs_n, DIR = O
 PORT ddr_memory_clk_n = ddr_memory_clk_n, DIR = O, SIGIS = CLK
 PORT ddr_memory_clk = ddr_memory_clk, DIR = O, SIGIS = CLK
 PORT ddr_memory_cke = ddr_memory_cke, DIR = O
 PORT ddr_memory_cas_n = ddr_memory_cas_n, DIR = O
 PORT ddr_memory_ba = ddr_memory_ba, DIR = O, VEC = [2:0]
 PORT ddr_memory_addr = ddr_memory_addr, DIR = O, VEC = [12:0]
 PORT SysACE_WEN = SysACE_WEN, DIR = O
 PORT SysACE_OEN = SysACE_OEN, DIR = O
 PORT SysACE_MPIRQ = SysACE_MPIRQ, DIR = I, SIGIS = INTERRUPT
 PORT SysACE_MPD = SysACE_MPD, DIR = IO, VEC = [7:0]
 PORT SysACE_MPA = SysACE_MPA, DIR = O, VEC = [6:0]
 PORT SysACE_CLK = SysACE_CLK, DIR = I
 PORT SysACE_CEN = SysACE_CEN, DIR = O
 PORT RS232_Uart_1_sout = RS232_Uart_1_sout, DIR = O
 PORT RS232_Uart_1_sin = RS232_Uart_1_sin, DIR = I
 PORT RESET = RESET, DIR = I, SIGIS = RST, RST_POLARITY = 1
 PORT Push_Buttons_5Bits_TRI_I = Push_Buttons_5Bits_TRI_I, DIR = I, VEC = [4:0]
 PORT Linear_Flash_we_n = Linear_Flash_we_n, DIR = O
 PORT Linear_Flash_oe_n = Linear_Flash_oe_n, DIR = O
 PORT Linear_Flash_data = Linear_Flash_data, DIR = IO, VEC = [0:15]
 PORT Linear_Flash_ce_n = Linear_Flash_ce_n, DIR = O
 PORT Linear_Flash_address = Linear_Flash_address, DIR = O, VEC = [0:23]
 PORT LEDs_Positions_TRI_O = LEDs_Positions_TRI_O, DIR = O, VEC = [4:0]
 PORT LEDs_8Bits_TRI_O = LEDs_8Bits_TRI_O, DIR = O, VEC = [7:0]
 PORT IIC_SFP_SDA = IIC_SFP_SDA, DIR = IO
 PORT IIC_SFP_SCL = IIC_SFP_SCL, DIR = IO
 PORT IIC_FMC_SDA = IIC_FMC_SDA, DIR = IO
 PORT IIC_FMC_SCL = IIC_FMC_SCL, DIR = IO
 PORT IIC_EEPROM_SDA = IIC_EEPROM_SDA, DIR = IO
 PORT IIC_EEPROM_SCL = IIC_EEPROM_SCL, DIR = IO
 PORT IIC_DVI_SDA = IIC_DVI_SDA, DIR = IO
 PORT IIC_DVI_SCL = IIC_DVI_SCL, DIR = IO
 PORT Ethernet_Lite_TX_EN = Ethernet_Lite_TX_EN, DIR = O
 PORT Ethernet_Lite_TX_CLK = Ethernet_Lite_TX_CLK, DIR = I
 PORT Ethernet_Lite_TXD = Ethernet_Lite_TXD, DIR = O, VEC = [3:0]
 PORT Ethernet_Lite_RX_ER = Ethernet_Lite_RX_ER, DIR = I
 PORT Ethernet_Lite_RX_DV = Ethernet_Lite_RX_DV, DIR = I
 PORT Ethernet_Lite_RX_CLK = Ethernet_Lite_RX_CLK, DIR = I
 PORT Ethernet_Lite_RXD = Ethernet_Lite_RXD, DIR = I, VEC = [3:0]
 PORT Ethernet_Lite_PHY_RST_N = Ethernet_Lite_PHY_RST_N, DIR = O
 PORT Ethernet_Lite_MDIO = Ethernet_Lite_MDIO, DIR = IO
 PORT Ethernet_Lite_MDC = Ethernet_Lite_MDC, DIR = O
 PORT Ethernet_Lite_CRS = Ethernet_Lite_CRS, DIR = I
 PORT Ethernet_Lite_COL = Ethernet_Lite_COL, DIR = I
 PORT DIP_Switches_8Bits_TRI_I = DIP_Switches_8Bits_TRI_I, DIR = I, VEC = [7:0]
 PORT CLK_P = CLK, DIR = I, DIFFERENTIAL_POLARITY = P, SIGIS = CLK, CLK_FREQ = 200000000
 PORT CLK_N = CLK, DIR = I, DIFFERENTIAL_POLARITY = N, SIGIS = CLK, CLK_FREQ = 200000000
BEGIN proc_sys_reset
 PARAMETER INSTANCE = proc_sys_reset_0
 PARAMETER HW_VER = 3.00.a
 PARAMETER C_EXT_RESET_HIGH = 1
 PORT MB_Debug_Sys_Rst = proc_sys_reset_0_MB_Debug_Sys_Rst
 PORT Dcm_locked = proc_sys_reset_0_Dcm_locked
 PORT MB_Reset = proc_sys_reset_0_MB_Reset
 PORT Slowest_sync_clk = clk_100_0000MHzMMCM0
 PORT Interconnect_aresetn = proc_sys_reset_0_Interconnect_aresetn
 PORT Ext_Reset_In = RESET
 PORT BUS_STRUCT_RESET = proc_sys_reset_0_BUS_STRUCT_RESET
END
BEGIN axi_intc
 PARAMETER INSTANCE = microblaze_0_intc
 PARAMETER HW_VER = 1.03.a
 PARAMETER C_BASEADDR = 0x41200000
 PARAMETER C_HIGHADDR = 0x4120ffff
 BUS_INTERFACE S_AXI = axi4lite_0
 BUS_INTERFACE INTERRUPT = microblaze_0_interrupt
 PORT S_AXI_ACLK = clk_100_0000MHzMMCM0
 PORT INTR = RS232_Uart_1_Interrupt & DIP_Switches_8Bits_IP2INTC_Irpt & LEDs_8Bits_IP2INTC_Irpt & LEDs_Positions_IP2INTC_Irpt & Push_Buttons_5Bits_IP2INTC_Irpt & IIC_EEPROM_IIC2INTC_Irpt & IIC_DVI_IIC2INTC_Irpt & IIC_FMC_IIC2INTC_Irpt & IIC_SFP_IIC2INTC_Irpt & SysACE_CompactFlash_SysACE_IRQ & Ethernet_Lite_IP2INTC_Irpt & axi_timer_0_Interrupt
END
BEGIN lmb_v10
 PARAMETER INSTANCE = microblaze_0_ilmb
 PARAMETER HW_VER = 2.00.b
 PORT SYS_RST = proc_sys_reset_0_BUS_STRUCT_RESET
 PORT LMB_CLK = clk_100_0000MHzMMCM0
END
BEGIN lmb_bram_if_cntlr
 PARAMETER INSTANCE = microblaze_0_i_bram_ctrl
 PARAMETER HW_VER = 3.10.b
 PARAMETER C_BASEADDR = 0x00000000
 PARAMETER C_HIGHADDR = 0x00001fff
 BUS_INTERFACE SLMB = microblaze_0_ilmb
 BUS_INTERFACE BRAM_PORT = microblaze_0_i_bram_ctrl_2_microblaze_0_bram_block
END
BEGIN lmb_v10
 PARAMETER INSTANCE = microblaze_0_dlmb
END
 PARAMETER INSTANCE = microblaze_0_d_bram_ctrl
 BUS_INTERFACE SLMB = microblaze_0_dlmb
 BUS_INTERFACE BRAM_PORT = microblaze_0_d_bram_ctrl_2_microblaze_0_bram_block
END
BEGIN bram_block
 PARAMETER INSTANCE = microblaze_0_bram_block
 PARAMETER HW_VER = 1.00.a
 BUS_INTERFACE PORTA = microblaze_0_i_bram_ctrl_2_microblaze_0_bram_block
 BUS_INTERFACE PORTB = microblaze_0_d_bram_ctrl_2_microblaze_0_bram_block
END
BEGIN microblaze
 PARAMETER HW_VER = 8.40.b
 PARAMETER C_INTERCONNECT = 2
 PARAMETER C_USE_BARREL = 1
 PARAMETER C_USE_FPU = 0
 PARAMETER C_DEBUG_ENABLED = 1
 PARAMETER C_ICACHE_BASEADDR = 0xc0000000
 PARAMETER C_ICACHE_HIGHADDR = 0xdfffffff
 PARAMETER C_USE_ICACHE = 1
 PARAMETER C_CACHE_BYTE_SIZE = 16384
 PARAMETER C_ICACHE_ALWAYS_USED = 1
 PARAMETER C_DCACHE_BASEADDR = 0xc0000000
 PARAMETER C_DCACHE_HIGHADDR = 0xdfffffff
 PARAMETER C_USE_DCACHE = 1
 PARAMETER C_DCACHE_BYTE_SIZE = 16384
 PARAMETER C_DCACHE_ALWAYS_USED = 1
 PARAMETER C_PVR = 2
 PARAMETER C_USE_MMU = 3
 PARAMETER C_MMU_ZONES = 2
 PARAMETER C_ICACHE_LINE_LEN = 8
 PARAMETER C_ICACHE_STREAMS = 1
 PARAMETER C_ICACHE_VICTIMS = 8
 PARAMETER C_DIV_ZERO_EXCEPTION = 1
 PARAMETER C_M_AXI_I_BUS_EXCEPTION = 1
 PARAMETER C_M_AXI_D_BUS_EXCEPTION = 1
 PARAMETER C_ILL_OPCODE_EXCEPTION = 1
 PARAMETER C_OPCODE_0x0_ILLEGAL = 1
 PARAMETER C_UNALIGNED_EXCEPTIONS = 1
 PARAMETER C_USE_HW_MUL = 2
 PARAMETER C_USE_DIV = 1
 BUS_INTERFACE M_AXI_DP = axi4lite_0
 BUS_INTERFACE M_AXI_IP = axi4lite_0
 BUS_INTERFACE M_AXI_DC = axi4_0
 BUS_INTERFACE M_AXI_IC = axi4_0
 BUS_INTERFACE DEBUG = microblaze_0_debug
 BUS_INTERFACE DLMB = microblaze_0_dlmb
 BUS_INTERFACE ILMB = microblaze_0_ilmb
 PORT MB_RESET = proc_sys_reset_0_MB_Reset
 PORT CLK = clk_100_0000MHzMMCM0
END
BEGIN mdm
 PARAMETER INSTANCE = debug_module
 PARAMETER HW_VER = 2.10.a
 PARAMETER C_USE_UART = 1
 PARAMETER C_BASEADDR = 0x41400000
 PARAMETER C_HIGHADDR = 0x4140ffff
 BUS_INTERFACE MBDEBUG_0 = microblaze_0_debug
 PORT Debug_SYS_Rst = proc_sys_reset_0_MB_Debug_Sys_Rst
END
BEGIN clock_generator
 PARAMETER INSTANCE = clock_generator_0
 PARAMETER HW_VER = 4.03.a
 PARAMETER C_CLKIN_FREQ = 200000000
 PARAMETER C_CLKOUT0_FREQ = 100000000
 PARAMETER C_CLKOUT0_GROUP = MMCM0
 PARAMETER C_CLKOUT1_FREQ = 200000000
 PARAMETER C_CLKOUT1_GROUP = MMCM0
 PARAMETER C_CLKOUT2_FREQ = 400000000
 PARAMETER C_CLKOUT2_GROUP = MMCM0
 PARAMETER C_CLKOUT3_FREQ = 400000000
 PARAMETER C_CLKOUT3_GROUP = MMCM0
 PARAMETER C_CLKOUT3_BUF = FALSE
 PARAMETER C_CLKOUT3_VARIABLE_PHASE = TRUE
 PORT LOCKED = proc_sys_reset_0_Dcm_locked
 PORT CLKOUT0 = clk_100_0000MHzMMCM0
 PORT RST = RESET
 PORT CLKOUT3 = clk_400_0000MHzMMCM0_nobuf_varphase
 PORT CLKOUT2 = clk_400_0000MHzMMCM0
 PORT CLKOUT1 = clk_200_0000MHzMMCM0
 PORT CLKIN = CLK
 PORT PSCLK = clk_200_0000MHzMMCM0
 PORT PSEN = psen
 PORT PSINCDEC = psincdec
 PORT PSDONE = psdone
END
BEGIN axi_timer
 PARAMETER INSTANCE = axi_timer_0
 PARAMETER C_COUNT_WIDTH = 32
 PARAMETER C_ONE_TIMER_ONLY = 0
 PARAMETER C_BASEADDR = 0x41c00000
 PARAMETER C_HIGHADDR = 0x41c0ffff
 PORT Interrupt = axi_timer_0_Interrupt
END
BEGIN axi_interconnect
 PARAMETER INSTANCE = axi4lite_0
 PARAMETER HW_VER = 1.06.a
 PARAMETER C_INTERCONNECT_CONNECTIVITY_MODE = 0
 PORT INTERCONNECT_ARESETN = proc_sys_reset_0_Interconnect_aresetn
 PORT INTERCONNECT_ACLK = clk_100_0000MHzMMCM0
END
 PARAMETER INSTANCE = axi4_0
 PORT interconnect_aclk = clk_100_0000MHzMMCM0
END
BEGIN axi_sysace
 PARAMETER INSTANCE = SysACE_CompactFlash
 PARAMETER HW_VER = 1.01.a
 PARAMETER C_MEM_WIDTH = 8
 PARAMETER C_BASEADDR = 0x41800000
 PARAMETER C_HIGHADDR = 0x4180ffff
 PORT SysACE_IRQ = SysACE_CompactFlash_SysACE_IRQ
END
BEGIN axi_uartlite
 PARAMETER INSTANCE = RS232_Uart_1
 PARAMETER HW_VER = 1.02.a
 PARAMETER C_BAUDRATE = 9600
 PARAMETER C_DATA_BITS = 8
 PARAMETER C_USE_PARITY = 0
 PARAMETER C_ODD_PARITY = 1
 PARAMETER C_BASEADDR = 0x40600000
 PARAMETER C_HIGHADDR = 0x4060ffff
 PORT TX = RS232_Uart_1_sout
 PORT RX = RS232_Uart_1_sin
 PORT Interrupt = RS232_Uart_1_Interrupt
END
BEGIN axi_gpio
 PARAMETER INSTANCE = Push_Buttons_5Bits
 PARAMETER HW_VER = 1.01.b
 PARAMETER C_GPIO_WIDTH = 5
 PARAMETER C_ALL_INPUTS = 1
 PARAMETER C_INTERRUPT_PRESENT = 1
 PARAMETER C_IS_DUAL = 0
 PARAMETER C_BASEADDR = 0x40000000
 PARAMETER C_HIGHADDR = 0x4000ffff
 PORT GPIO_IO_I = Push_Buttons_5Bits_TRI_I
 PORT IP2INTC_Irpt = Push_Buttons_5Bits_IP2INTC_Irpt
END
BEGIN util_vector_logic
 PARAMETER INSTANCE = Linear_Flash_invertor
 PARAMETER C_OPERATION = not
 PARAMETER C_SIZE = 1
 PORT Op1 = Linear_Flash_invertor_Op1_Adhoc
 PORT Res = Linear_Flash_ce_n
END
BEGIN axi_emc
 PARAMETER C_NUM_BANKS_MEM = 1
 PARAMETER C_MEM0_WIDTH = 16
 PARAMETER C_INCLUDE_DATAWIDTH_MATCHING_0 = 1
 PARAMETER C_MEM0_TYPE = 2
 PARAMETER C_TCEDV_PS_MEM_0 = 130000
 PARAMETER C_TAVDV_PS_MEM_0 = 130000
 PARAMETER C_THZCE_PS_MEM_0 = 35000
 PARAMETER C_TWC_PS_MEM_0 = 70000
 PARAMETER C_TWP_PS_MEM_0 = 70000
 PARAMETER C_TLZWE_PS_MEM_0 = 35000
 PARAMETER C_MAX_MEM_WIDTH = 16
 PARAMETER C_S_AXI_MEM0_BASEADDR = 0x42000000
 PARAMETER C_S_AXI_MEM0_HIGHADDR = 0x43ffffff
 BUS_INTERFACE S_AXI_MEM = axi4lite_0
 PORT RdClk = clk_100_0000MHzMMCM0
 PORT Mem_WEN = Linear_Flash_we_n
 PORT Mem_OEN = Linear_Flash_oe_n
 PORT Mem_CEN = Linear_Flash_invertor_Op1_Adhoc
 PORT Mem_DQ = Linear_Flash_data
 PORT Mem_A = 0b0000000 & Linear_Flash_address & 0b0
END
BEGIN axi_gpio
 PARAMETER INSTANCE = LEDs_Positions
 PARAMETER C_ALL_INPUTS = 0
 PARAMETER C_BASEADDR = 0x40020000
 PARAMETER C_HIGHADDR = 0x4002ffff
 PORT GPIO_IO_O = LEDs_Positions_TRI_O
 PORT IP2INTC_Irpt = LEDs_Positions_IP2INTC_Irpt
END
BEGIN axi_gpio
 PARAMETER INSTANCE = LEDs_8Bits
 PARAMETER C_GPIO_WIDTH = 8
 PARAMETER C_BASEADDR = 0x40040000
 PARAMETER C_HIGHADDR = 0x4004ffff
 PORT GPIO_IO_O = LEDs_8Bits_TRI_O
 PORT IP2INTC_Irpt = LEDs_8Bits_IP2INTC_Irpt
END
BEGIN axi_iic
 PARAMETER INSTANCE = IIC_SFP
 PARAMETER C_IIC_FREQ = 100000
 PARAMETER C_TEN_BIT_ADR = 0
 PARAMETER C_BASEADDR = 0x40800000
 PARAMETER C_HIGHADDR = 0x4080ffff
 PORT Sda = IIC_SFP_SDA
 PORT Scl = IIC_SFP_SCL
 PORT IIC2INTC_Irpt = IIC_SFP_IIC2INTC_Irpt
END
BEGIN axi_iic
 PARAMETER INSTANCE = IIC_FMC
 PARAMETER C_BASEADDR = 0x40820000
 PARAMETER C_HIGHADDR = 0x4082ffff
 PORT Sda = IIC_FMC_SDA
 PORT Scl = IIC_FMC_SCL
 PORT IIC2INTC_Irpt = IIC_FMC_IIC2INTC_Irpt
END
BEGIN axi_iic
 PARAMETER INSTANCE = IIC_EEPROM
 PARAMETER C_BASEADDR = 0x40840000
 PARAMETER C_HIGHADDR = 0x4084ffff
 PORT Sda = IIC_EEPROM_SDA
 PORT Scl = IIC_EEPROM_SCL
 PORT IIC2INTC_Irpt = IIC_EEPROM_IIC2INTC_Irpt
END
BEGIN axi_iic
 PARAMETER INSTANCE = IIC_DVI
 PARAMETER C_BASEADDR = 0x40860000
 PARAMETER C_HIGHADDR = 0x4086ffff
 PORT Sda = IIC_DVI_SDA
 PORT Scl = IIC_DVI_SCL
 PORT IIC2INTC_Irpt = IIC_DVI_IIC2INTC_Irpt
END
BEGIN axi_ethernetlite
 PARAMETER INSTANCE = Ethernet_Lite
 PARAMETER C_BASEADDR = 0x40e00000
 PARAMETER C_HIGHADDR = 0x40e0ffff
 PORT PHY_tx_en = Ethernet_Lite_TX_EN
 PORT PHY_tx_clk = Ethernet_Lite_TX_CLK
 PORT PHY_tx_data = Ethernet_Lite_TXD
 PORT PHY_rx_er = Ethernet_Lite_RX_ER
 PORT PHY_dv = Ethernet_Lite_RX_DV
 PORT PHY_rx_clk = Ethernet_Lite_RX_CLK
 PORT PHY_rx_data = Ethernet_Lite_RXD
 PORT PHY_rst_n = Ethernet_Lite_PHY_RST_N
 PORT PHY_MDIO = Ethernet_Lite_MDIO
 PORT PHY_MDC = Ethernet_Lite_MDC
 PORT PHY_crs = Ethernet_Lite_CRS
 PORT PHY_col = Ethernet_Lite_COL
 PORT IP2INTC_Irpt = Ethernet_Lite_IP2INTC_Irpt
END
BEGIN axi_gpio
 PARAMETER INSTANCE = DIP_Switches_8Bits
 PARAMETER C_BASEADDR = 0x40060000
 PARAMETER C_HIGHADDR = 0x4006ffff
 PORT GPIO_IO_I = DIP_Switches_8Bits_TRI_I
 PORT IP2INTC_Irpt = DIP_Switches_8Bits_IP2INTC_Irpt
END
BEGIN axi_v6_ddrx
 PARAMETER INSTANCE = DDR3_SDRAM
 PARAMETER C_MEM_PARTNO = MT41J64M16XX-15E
 PARAMETER C_DM_WIDTH = 1
 PARAMETER C_DQS_WIDTH = 1
 PARAMETER C_DQ_WIDTH = 8
 PARAMETER C_INTERCONNECT_S_AXI_MASTERS = microblaze_0.M_AXI_DC & microblaze_0.M_AXI_IC
 PARAMETER C_MMCM_EXT_LOC = MMCM_ADV_X0Y8
 PARAMETER C_NDQS_COL0 = 1
 PARAMETER C_NDQS_COL1 = 0
 PARAMETER C_S_AXI_BASEADDR = 0xa4000000
 PARAMETER C_S_AXI_HIGHADDR = 0xa7ffffff
 BUS_INTERFACE S_AXI = axi4_0
 PORT ddr_we_n = ddr_memory_we_n
 PORT ddr_ras_n = ddr_memory_ras_n
 PORT ddr_odt = ddr_memory_odt
 PORT ddr_dqs_n = ddr_memory_dqs_n
 PORT ddr_dqs_p = ddr_memory_dqs
 PORT ddr_dq = ddr_memory_dq
 PORT ddr_dm = ddr_memory_dm
 PORT ddr_reset_n = ddr_memory_ddr3_rst
 PORT ddr_cs_n = ddr_memory_cs_n
 PORT ddr_ck_n = ddr_memory_clk_n
 PORT ddr_ck_p = ddr_memory_clk
 PORT ddr_cke = ddr_memory_cke
 PORT ddr_cas_n = ddr_memory_cas_n
 PORT ddr_ba = ddr_memory_ba
 PORT ddr_addr = ddr_memory_addr
 PORT clk_rd_base = clk_400_0000MHzMMCM0_nobuf_varphase
 PORT clk_mem = clk_400_0000MHzMMCM0
 PORT clk = clk_200_0000MHzMMCM0
 PORT clk_ref = clk_200_0000MHzMMCM0
 PORT PD_PSEN = psen
 PORT PD_PSINCDEC = psincdec
 PORT PD_PSDONE = psdone
END
 * Device Tree Generator version: 1.3
 * (C) Copyright 2007-2008 Xilinx, Inc.
 * (C) Copyright 2007-2009 Michal Simek
 * Michal SIMEK <monstr@monstr.eu>
 * This program is free software; you can redistribute it and/or
 * modify it under the terms of the GNU General Public License as
 * published by the Free Software Foundation; either version 2 of
 * the License, or (at your option) any later version.
 * This program is distributed in the hope that it will be useful,
 * but WITHOUT ANY WARRANTY; without even the implied warranty of
 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
 * GNU General Public License for more details.
 * You should have received a copy of the GNU General Public License
 * along with this program; if not, write to the Free Software
 * Foundation, Inc., 59 Temple Place, Suite 330, Boston,
 * MA 02111-1307 USA
 * CAUTION: This file is automatically generated by libgen.
 * Version: Xilinx EDK 14.3 EDK_P.40xd
 * XPS project directory: device-tree_bsp_0
/dts-v1/;
	#address-cells = <1>;
	#size-cells = <1>;
	compatible = "xlnx,microblaze";
	model = "testing";
	aliases {
		ethernet0 = &ethernet_lite;
		serial0 = &rs232_uart_1;
	chosen {
		bootargs = "console=ttyS0 root=/dev/ram";
	cpus {
		#cpus = <0x1>;
		#size-cells = <0>;
		microblaze_0: cpu@0 {
			clock-frequency = <100000000>;
			compatible = "xlnx,microblaze-8.40.b";
			d-cache-baseaddr = <0xc0000000>;
			d-cache-highaddr = <0xdfffffff>;
			d-cache-line-size = <0x10>;
			d-cache-size = <0x4000>;
			device_type = "cpu";
			i-cache-baseaddr = <0xc0000000>;
			i-cache-highaddr = <0xdfffffff>;
			i-cache-line-size = <0x20>;
			i-cache-size = <0x4000>;
			model = "microblaze,8.40.b";
			reg = <0>;
			timebase-frequency = <100000000>;
			xlnx,addr-tag-bits = <0xf>;
			xlnx,allow-dcache-wr = <0x1>;
			xlnx,allow-icache-wr = <0x1>;
			xlnx,area-optimized = <0x0>;
			xlnx,avoid-primitives = <0x0>;
			xlnx,base-vectors = <0x0>;
			xlnx,branch-target-cache-size = <0x0>;
			xlnx,cache-byte-size = <0x4000>;
			xlnx,d-axi = <0x1>;
			xlnx,d-lmb = <0x1>;
			xlnx,d-plb = <0x0>;
			xlnx,data-size = <0x20>;
			xlnx,dcache-addr-tag = <0xf>;
			xlnx,dcache-always-used = <0x1>;
			xlnx,dcache-byte-size = <0x4000>;
			xlnx,dcache-data-width = <0x0>;
			xlnx,dcache-force-tag-lutram = <0x0>;
			xlnx,dcache-interface = <0x0>;
			xlnx,dcache-line-len = <0x4>;
			xlnx,dcache-use-fsl = <0x0>;
			xlnx,dcache-use-writeback = <0x0>;
			xlnx,dcache-victims = <0x0>;
			xlnx,debug-enabled = <0x1>;
			xlnx,div-zero-exception = <0x1>;
			xlnx,dynamic-bus-sizing = <0x1>;
			xlnx,ecc-use-ce-exception = <0x0>;
			xlnx,edge-is-positive = <0x1>;
			xlnx,endianness = <0x1>;
			xlnx,family = "virtex6";
			xlnx,fault-tolerant = <0x0>;
			xlnx,fpu-exception = <0x0>;
			xlnx,freq = <0x5f5e100>;
			xlnx,fsl-data-size = <0x20>;
			xlnx,fsl-exception = <0x0>;
			xlnx,fsl-links = <0x0>;
			xlnx,i-axi = <0x1>;
			xlnx,i-lmb = <0x1>;
			xlnx,i-plb = <0x0>;
			xlnx,icache-always-used = <0x1>;
			xlnx,icache-data-width = <0x0>;
			xlnx,icache-force-tag-lutram = <0x0>;
			xlnx,icache-interface = <0x0>;
			xlnx,icache-line-len = <0x8>;
			xlnx,icache-streams = <0x1>;
			xlnx,icache-use-fsl = <0x0>;
			xlnx,icache-victims = <0x8>;
			xlnx,ill-opcode-exception = <0x1>;
			xlnx,instance = "microblaze_0";
			xlnx,interconnect = <0x2>;
			xlnx,interrupt-is-edge = <0x0>;
			xlnx,lockstep-slave = <0x0>;
			xlnx,mmu-dtlb-size = <0x4>;
			xlnx,mmu-itlb-size = <0x2>;
			xlnx,mmu-privileged-instr = <0x0>;
			xlnx,mmu-tlb-access = <0x3>;
			xlnx,mmu-zones = <0x2>;
			xlnx,number-of-pc-brk = <0x1>;
			xlnx,number-of-rd-addr-brk = <0x0>;
			xlnx,number-of-wr-addr-brk = <0x0>;
			xlnx,opcode-0x0-illegal = <0x1>;
			xlnx,optimization = <0x0>;
			xlnx,pc-width = <0x20>;
			xlnx,pvr = <0x2>;
			xlnx,pvr-user1 = <0x0>;
			xlnx,pvr-user2 = <0x0>;
			xlnx,reset-msr = <0x0>;
			xlnx,sco = <0x0>;
			xlnx,stream-interconnect = <0x0>;
			xlnx,unaligned-exceptions = <0x1>;
			xlnx,use-barrel = <0x1>;
			xlnx,use-branch-target-cache = <0x0>;
			xlnx,use-dcache = <0x1>;
			xlnx,use-div = <0x1>;
			xlnx,use-ext-brk = <0x1>;
			xlnx,use-ext-nm-brk = <0x1>;
			xlnx,use-extended-fsl-instr = <0x0>;
			xlnx,use-fpu = <0x0>;
			xlnx,use-hw-mul = <0x2>;
			xlnx,use-icache = <0x1>;
			xlnx,use-interrupt = <0x1>;
			xlnx,use-mmu = <0x3>;
			xlnx,use-msr-instr = <0x1>;
			xlnx,use-pcmp-instr = <0x1>;
			xlnx,use-reorder-instr = <0x1>;
			xlnx,use-stack-protection = <0x0>;
	ddr3_sdram: memory@a4000000 {
		device_type = "memory";
		reg = < 0xa4000000 0x4000000 >;
	axi4lite_0: axi@0 {
		#size-cells = <1>;
		compatible = "xlnx,axi-interconnect-1.06.a", "simple-bus";
		ranges ;
		axi_timer_0: timer@41c00000 {
			compatible = "xlnx,axi-timer-1.03.a", "xlnx,xps-timer-1.00.a";
			interrupt-parent = <&microblaze_0_intc>;
			interrupts = < 0 2 >;
			reg = < 0x41c00000 0x10000 >;
			xlnx,count-width = <0x20>;
			xlnx,gen0-assert = <0x1>;
			xlnx,gen1-assert = <0x1>;
			xlnx,instance = "axi_timer_0";
			xlnx,one-timer-only = <0x0>;
			xlnx,trig0-assert = <0x1>;
			xlnx,trig1-assert = <0x1>;
		debug_module: debug@41400000 {
			compatible = "xlnx,mdm-2.10.a";
			reg = < 0x41400000 0x10000 >;
			xlnx,jtag-chain = <0x2>;
			xlnx,mb-dbg-ports = <0x1>;
			xlnx,use-bscan = <0x0>;
			xlnx,use-uart = <0x1>;
		dip_switches_8bits: gpio@40060000 {
			compatible = "xlnx,axi-gpio-1.01.b", "xlnx,xps-gpio-1.00.a";
			interrupts = < 10 2 >;
			reg = < 0x40060000 0x10000 >;
			xlnx,all-inputs = <0x1>;
			xlnx,all-inputs-2 = <0x0>;
			xlnx,dout-default = <0x0>;
			xlnx,dout-default-2 = <0x0>;
			xlnx,gpio-width = <0x8>;
			xlnx,gpio2-width = <0x20>;
			xlnx,instance = "DIP_Switches_8Bits";
			xlnx,interrupt-present = <0x1>;
			xlnx,is-dual = <0x0>;
			xlnx,tri-default = <0xffffffff>;
			xlnx,tri-default-2 = <0xffffffff>;
		ethernet_lite: ethernet@40e00000 {
			compatible = "xlnx,axi-ethernetlite-1.01.b", "xlnx,xps-ethernetlite-1.00.a";
			device_type = "network";
			interrupts = < 1 0 >;
			local-mac-address = [ 00 0a 35 20 4e 00 ];
			phy-handle = <&phy0>;
			reg = < 0x40e00000 0x10000 >;
			xlnx,duplex = <0x1>;
			xlnx,include-global-buffers = <0x0>;
			xlnx,include-internal-loopback = <0x0>;
			xlnx,include-mdio = <0x1>;
			xlnx,include-phy-constraints = <0x1>;
			xlnx,instance = "Ethernet_Lite";
			xlnx,rx-ping-pong = <0x0>;
			xlnx,s-axi-aclk-period-ps = <0x2710>;
			xlnx,s-axi-id-width = <0x1>;
			xlnx,s-axi-supports-narrow-burst = <0x0>;
			xlnx,tx-ping-pong = <0x0>;
			mdio {
				#size-cells = <0>;
				phy0: phy@7 {
					compatible = "marvell,88e1111";
					device_type = "ethernet-phy";
					reg = <7>;
		iic_dvi: i2c@40860000 {
			compatible = "xlnx,axi-iic-1.02.a", "xlnx,xps-iic-2.00.a";
			interrupts = < 5 2 >;
			reg = < 0x40860000 0x10000 >;
			xlnx,gpo-width = <0x1>;
			xlnx,iic-freq = <0x186a0>;
			xlnx,instance = "IIC_DVI";
			xlnx,s-axi-aclk-freq-hz = <0x5f5e100>;
			xlnx,scl-inertial-delay = <0x0>;
			xlnx,sda-inertial-delay = <0x0>;
			xlnx,sda-level = <0x1>;
			xlnx,ten-bit-adr = <0x0>;
		iic_eeprom: i2c@40840000 {
			interrupts = < 6 2 >;
			reg = < 0x40840000 0x10000 >;
			xlnx,instance = "IIC_EEPROM";
		iic_fmc: i2c@40820000 {
			interrupts = < 4 2 >;
			reg = < 0x40820000 0x10000 >;
			xlnx,instance = "IIC_FMC";
		iic_sfp: i2c@40800000 {
			interrupts = < 3 2 >;
			reg = < 0x40800000 0x10000 >;
			xlnx,instance = "IIC_SFP";
		leds_8bits: gpio@40040000 {
			interrupts = < 9 2 >;
			reg = < 0x40040000 0x10000 >;
			xlnx,all-inputs = <0x0>;
			xlnx,instance = "LEDs_8Bits";
		leds_positions: gpio@40020000 {
			interrupts = < 8 2 >;
			reg = < 0x40020000 0x10000 >;
			xlnx,gpio-width = <0x5>;
			xlnx,instance = "LEDs_Positions";
		linear_flash: flash@42000000 {
			bank-width = <2>;
			compatible = "xlnx,axi-emc-1.03.a", "cfi-flash";
			reg = < 0x42000000 0x2000000 >;
			xlnx,axi-clk-period-ps = <0x2710>;
			xlnx,include-datawidth-matching-0 = <0x1>;
			xlnx,include-datawidth-matching-1 = <0x0>;
			xlnx,include-datawidth-matching-2 = <0x0>;
			xlnx,include-datawidth-matching-3 = <0x0>;
			xlnx,include-negedge-ioregs = <0x0>;
			xlnx,instance = "Linear_Flash";
			xlnx,lflash-period-ps = <0x4e20>;
			xlnx,linear-flash-sync-burst = <0x0>;
			xlnx,max-mem-width = <0x10>;
			xlnx,mem0-type = <0x2>;
			xlnx,mem0-width = <0x10>;
			xlnx,mem1-type = <0x0>;
			xlnx,mem1-width = <0x20>;
			xlnx,mem2-type = <0x0>;
			xlnx,mem2-width = <0x20>;
			xlnx,mem3-type = <0x0>;
			xlnx,mem3-width = <0x20>;
			xlnx,num-banks-mem = <0x1>;
			xlnx,parity-type-mem-0 = <0x0>;
			xlnx,parity-type-mem-1 = <0x0>;
			xlnx,parity-type-mem-2 = <0x0>;
			xlnx,parity-type-mem-3 = <0x0>;
			xlnx,s-axi-en-reg = <0x0>;
			xlnx,s-axi-mem-addr-width = <0x20>;
			xlnx,s-axi-mem-data-width = <0x20>;
			xlnx,s-axi-mem-id-width = <0x1>;
			xlnx,s-axi-mem-protocol = "AXI4LITE";
			xlnx,s-axi-reg-addr-width = <0x5>;
			xlnx,s-axi-reg-data-width = <0x20>;
			xlnx,s-axi-reg-protocol = "axi4";
			xlnx,synch-pipedelay-0 = <0x2>;
			xlnx,synch-pipedelay-1 = <0x2>;
			xlnx,synch-pipedelay-2 = <0x2>;
			xlnx,synch-pipedelay-3 = <0x2>;
			xlnx,tavdv-ps-mem-0 = <0x1fbd0>;
			xlnx,tavdv-ps-mem-1 = <0x3a98>;
			xlnx,tavdv-ps-mem-2 = <0x3a98>;
			xlnx,tavdv-ps-mem-3 = <0x3a98>;
			xlnx,tcedv-ps-mem-0 = <0x1fbd0>;
			xlnx,tcedv-ps-mem-1 = <0x3a98>;
			xlnx,tcedv-ps-mem-2 = <0x3a98>;
			xlnx,tcedv-ps-mem-3 = <0x3a98>;
			xlnx,thzce-ps-mem-0 = <0x88b8>;
			xlnx,thzce-ps-mem-1 = <0x1b58>;
			xlnx,thzce-ps-mem-2 = <0x1b58>;
			xlnx,thzce-ps-mem-3 = <0x1b58>;
			xlnx,thzoe-ps-mem-0 = <0x1b58>;
			xlnx,thzoe-ps-mem-1 = <0x1b58>;
			xlnx,thzoe-ps-mem-2 = <0x1b58>;
			xlnx,thzoe-ps-mem-3 = <0x1b58>;
			xlnx,tlzwe-ps-mem-0 = <0x88b8>;
			xlnx,tlzwe-ps-mem-1 = <0x0>;
			xlnx,tlzwe-ps-mem-2 = <0x0>;
			xlnx,tlzwe-ps-mem-3 = <0x0>;
			xlnx,tpacc-ps-flash-0 = <0x61a8>;
			xlnx,tpacc-ps-flash-1 = <0x61a8>;
			xlnx,tpacc-ps-flash-2 = <0x61a8>;
			xlnx,tpacc-ps-flash-3 = <0x61a8>;
			xlnx,twc-ps-mem-0 = <0x11170>;
			xlnx,twc-ps-mem-1 = <0x3a98>;
			xlnx,twc-ps-mem-2 = <0x3a98>;
			xlnx,twc-ps-mem-3 = <0x3a98>;
			xlnx,twp-ps-mem-0 = <0x11170>;
			xlnx,twp-ps-mem-1 = <0x2ee0>;
			xlnx,twp-ps-mem-2 = <0x2ee0>;
			xlnx,twp-ps-mem-3 = <0x2ee0>;
			xlnx,twph-ps-mem-0 = <0x2ee0>;
			xlnx,twph-ps-mem-1 = <0x2ee0>;
			xlnx,twph-ps-mem-2 = <0x2ee0>;
			xlnx,twph-ps-mem-3 = <0x2ee0>;
			xlnx,wr-rec-time-mem-0 = <0x186a0>;
			xlnx,wr-rec-time-mem-1 = <0x186a0>;
			xlnx,wr-rec-time-mem-2 = <0x186a0>;
			xlnx,wr-rec-time-mem-3 = <0x186a0>;
		microblaze_0_intc: interrupt-controller@41200000 {
			#interrupt-cells = <0x2>;
			compatible = "xlnx,axi-intc-1.03.a", "xlnx,xps-intc-1.00.a";
			interrupt-controller ;
			reg = < 0x41200000 0x10000 >;
			xlnx,kind-of-intr = <0x802>;
			xlnx,num-intr-inputs = <0xc>;
		push_buttons_5bits: gpio@40000000 {
			interrupts = < 7 2 >;
			reg = < 0x40000000 0x10000 >;
			xlnx,instance = "Push_Buttons_5Bits";
		rs232_uart_1: serial@40600000 {
			compatible = "xlnx,axi-uartlite-1.02.a", "xlnx,xps-uartlite-1.00.a";
			current-speed = <9600>;
			device_type = "serial";
			interrupts = < 11 0 >;
			port-number = <0>;
			reg = < 0x40600000 0x10000 >;
			xlnx,baudrate = <0x2580>;
			xlnx,data-bits = <0x8>;
			xlnx,instance = "RS232_Uart_1";
			xlnx,odd-parity = <0x1>;
			xlnx,use-parity = <0x0>;
		sysace_compactflash: sysace@41800000 {
			8-bit ;
			compatible = "xlnx,axi-sysace-1.01.a", "xlnx,xps-sysace-1.00.a";
			interrupts = < 2 2 >;
			reg = < 0x41800000 0x10000 >;
			xlnx,instance = "SysACE_CompactFlash";
			xlnx,mem-width = <0x8>;
# Automatically generated make config: don't edit
# Linux/microblaze 3.0.0 Kernel Configuration
CONFIG_MICROBLAZE=y
# CONFIG_SWAP is not set
CONFIG_RWSEM_GENERIC_SPINLOCK=y
# CONFIG_ARCH_HAS_ILOG2_U32 is not set
# CONFIG_ARCH_HAS_ILOG2_U64 is not set
CONFIG_GENERIC_HWEIGHT=y
CONFIG_GENERIC_CALIBRATE_DELAY=y
# CONFIG_GENERIC_TIME_VSYSCALL is not set
CONFIG_GENERIC_CLOCKEVENTS=y
CONFIG_GENERIC_GPIO=y
CONFIG_GENERIC_CSUM=y
CONFIG_STACKTRACE_SUPPORT=y
CONFIG_LOCKDEP_SUPPORT=y
CONFIG_HAVE_LATENCYTOP_SUPPORT=y
CONFIG_DEFCONFIG_LIST="/lib/modules/$UNAME_RELEASE/.config"
# General setup
CONFIG_EXPERIMENTAL=y
CONFIG_BROKEN_ON_SMP=y
CONFIG_INIT_ENV_ARG_LIMIT=32
CONFIG_CROSS_COMPILE=""
CONFIG_LOCALVERSION=""
CONFIG_LOCALVERSION_AUTO=y
CONFIG_DEFAULT_HOSTNAME="(none)"
CONFIG_SYSVIPC=y
CONFIG_SYSVIPC_SYSCTL=y
# CONFIG_POSIX_MQUEUE is not set
# CONFIG_BSD_PROCESS_ACCT is not set
# CONFIG_FHANDLE is not set
# CONFIG_TASKSTATS is not set
# CONFIG_AUDIT is not set
CONFIG_HAVE_GENERIC_HARDIRQS=y
# IRQ subsystem
CONFIG_GENERIC_HARDIRQS=y
CONFIG_GENERIC_IRQ_PROBE=y
CONFIG_GENERIC_IRQ_SHOW=y
# RCU Subsystem
CONFIG_TINY_RCU=y
# CONFIG_PREEMPT_RCU is not set
# CONFIG_RCU_TRACE is not set
# CONFIG_TREE_RCU_TRACE is not set
CONFIG_IKCONFIG=y
CONFIG_IKCONFIG_PROC=y
CONFIG_LOG_BUF_SHIFT=17
# CONFIG_CGROUPS is not set
# CONFIG_NAMESPACES is not set
# CONFIG_SCHED_AUTOGROUP is not set
CONFIG_SYSFS_DEPRECATED=y
CONFIG_SYSFS_DEPRECATED_V2=y
# CONFIG_RELAY is not set
CONFIG_BLK_DEV_INITRD=y
# CONFIG_INITRAMFS_NO_CHECK is not set
CONFIG_INITRAMFS_SOURCE="initramfs_minimal.cpio.gz"
CONFIG_INITRAMFS_ROOT_UID=0
CONFIG_INITRAMFS_ROOT_GID=0
CONFIG_RD_GZIP=y
# CONFIG_RD_BZIP2 is not set
# CONFIG_RD_LZMA is not set
# CONFIG_RD_XZ is not set
# CONFIG_RD_LZO is not set
CONFIG_INITRAMFS_COMPRESSION_NONE=y
# CONFIG_INITRAMFS_COMPRESSION_GZIP is not set
# CONFIG_CC_OPTIMIZE_FOR_SIZE is not set
CONFIG_SYSCTL=y
CONFIG_ANON_INODES=y
CONFIG_EXPERT=y
CONFIG_SYSCTL_SYSCALL=y
CONFIG_KALLSYMS=y
# CONFIG_HOTPLUG is not set
CONFIG_PRINTK=y
CONFIG_BUG=y
CONFIG_ELF_CORE=y
# CONFIG_BASE_FULL is not set
# CONFIG_FUTEX is not set
# CONFIG_EPOLL is not set
# CONFIG_SIGNALFD is not set
CONFIG_TIMERFD=y
CONFIG_EVENTFD=y
# CONFIG_SHMEM is not set
CONFIG_AIO=y
CONFIG_EMBEDDED=y
# Kernel Performance Events And Counters
CONFIG_VM_EVENT_COUNTERS=y
CONFIG_COMPAT_BRK=y
CONFIG_SLAB=y
# CONFIG_SLUB is not set
# CONFIG_SLOB is not set
# CONFIG_PROFILING is not set
CONFIG_HAVE_OPROFILE=y
CONFIG_HAVE_DMA_ATTRS=y
CONFIG_HAVE_DMA_API_DEBUG=y
# GCOV-based kernel profiling
# CONFIG_HAVE_GENERIC_DMA_COHERENT is not set
CONFIG_SLABINFO=y
CONFIG_RT_MUTEXES=y
CONFIG_BASE_SMALL=1
CONFIG_MODULES=y
# CONFIG_MODULE_FORCE_LOAD is not set
CONFIG_MODULE_UNLOAD=y
# CONFIG_MODULE_FORCE_UNLOAD is not set
# CONFIG_MODVERSIONS is not set
# CONFIG_MODULE_SRCVERSION_ALL is not set
CONFIG_BLOCK=y
CONFIG_LBDAF=y
# CONFIG_BLK_DEV_BSG is not set
# CONFIG_BLK_DEV_INTEGRITY is not set
# IO Schedulers
CONFIG_IOSCHED_NOOP=y
CONFIG_IOSCHED_DEADLINE=y
CONFIG_IOSCHED_CFQ=y
# CONFIG_DEFAULT_DEADLINE is not set
CONFIG_DEFAULT_CFQ=y
# CONFIG_DEFAULT_NOOP is not set
CONFIG_DEFAULT_IOSCHED="cfq"
# CONFIG_INLINE_SPIN_TRYLOCK is not set
# CONFIG_INLINE_SPIN_TRYLOCK_BH is not set
# CONFIG_INLINE_SPIN_LOCK is not set
# CONFIG_INLINE_SPIN_LOCK_BH is not set
# CONFIG_INLINE_SPIN_LOCK_IRQ is not set
# CONFIG_INLINE_SPIN_LOCK_IRQSAVE is not set
CONFIG_INLINE_SPIN_UNLOCK=y
# CONFIG_INLINE_SPIN_UNLOCK_BH is not set
CONFIG_INLINE_SPIN_UNLOCK_IRQ=y
# CONFIG_INLINE_SPIN_UNLOCK_IRQRESTORE is not set
# CONFIG_INLINE_READ_TRYLOCK is not set
# CONFIG_INLINE_READ_LOCK is not set
# CONFIG_INLINE_READ_LOCK_BH is not set
# CONFIG_INLINE_READ_LOCK_IRQ is not set
# CONFIG_INLINE_READ_LOCK_IRQSAVE is not set
CONFIG_INLINE_READ_UNLOCK=y
# CONFIG_INLINE_READ_UNLOCK_BH is not set
CONFIG_INLINE_READ_UNLOCK_IRQ=y
# CONFIG_INLINE_READ_UNLOCK_IRQRESTORE is not set
# CONFIG_INLINE_WRITE_TRYLOCK is not set
# CONFIG_INLINE_WRITE_LOCK is not set
# CONFIG_INLINE_WRITE_LOCK_BH is not set
# CONFIG_INLINE_WRITE_LOCK_IRQ is not set
# CONFIG_INLINE_WRITE_LOCK_IRQSAVE is not set
CONFIG_INLINE_WRITE_UNLOCK=y
# CONFIG_INLINE_WRITE_UNLOCK_BH is not set
CONFIG_INLINE_WRITE_UNLOCK_IRQ=y
# CONFIG_INLINE_WRITE_UNLOCK_IRQRESTORE is not set
# CONFIG_MUTEX_SPIN_ON_OWNER is not set
# CONFIG_FREEZER is not set
# Platform options
CONFIG_PLATFORM_GENERIC=y
CONFIG_OPT_LIB_FUNCTION=y
# CONFIG_OPT_LIB_ASM is not set
# Definitions for MICROBLAZE0
CONFIG_KERNEL_BASE_ADDR=0xC0000000
CONFIG_XILINX_MICROBLAZE0_FAMILY="virtex6"
CONFIG_XILINX_MICROBLAZE0_USE_MSR_INSTR=1
CONFIG_XILINX_MICROBLAZE0_USE_PCMP_INSTR=1
CONFIG_XILINX_MICROBLAZE0_USE_BARREL=1
CONFIG_XILINX_MICROBLAZE0_USE_DIV=1
CONFIG_XILINX_MICROBLAZE0_USE_HW_MUL=2
CONFIG_XILINX_MICROBLAZE0_USE_FPU=0
CONFIG_XILINX_MICROBLAZE0_HW_VER="8.40.b"
# Processor type and features
# CONFIG_NO_HZ is not set
# CONFIG_HIGH_RES_TIMERS is not set
CONFIG_GENERIC_CLOCKEVENTS_BUILD=y
CONFIG_PREEMPT_NONE=y
# CONFIG_PREEMPT_VOLUNTARY is not set
# CONFIG_PREEMPT is not set
CONFIG_HZ_100=y
# CONFIG_HZ_250 is not set
# CONFIG_HZ_300 is not set
# CONFIG_HZ_1000 is not set
CONFIG_HZ=100
# CONFIG_SCHED_HRTICK is not set
CONFIG_MMU=y
# Boot options
# CONFIG_CMDLINE_BOOL is not set
CONFIG_SECCOMP=y
# Advanced setup
# CONFIG_ADVANCED_OPTIONS is not set
# Default settings for advanced configuration options are used
CONFIG_HIGHMEM_START=0xfe000000
CONFIG_LOWMEM_SIZE=0x30000000
CONFIG_MANUAL_RESET_VECTOR=0x0
CONFIG_KERNEL_START=0xc0000000
CONFIG_TASK_SIZE=0x80000000
CONFIG_SELECT_MEMORY_MODEL=y
CONFIG_FLATMEM_MANUAL=y
CONFIG_FLATMEM=y
CONFIG_FLAT_NODE_MEM_MAP=y
CONFIG_HAVE_MEMBLOCK=y
CONFIG_PAGEFLAGS_EXTENDED=y
CONFIG_SPLIT_PTLOCK_CPUS=4
# CONFIG_COMPACTION is not set
# CONFIG_PHYS_ADDR_T_64BIT is not set
CONFIG_ZONE_DMA_FLAG=0
CONFIG_VIRT_TO_BUS=y
# CONFIG_KSM is not set
CONFIG_DEFAULT_MMAP_MIN_ADDR=4096
CONFIG_NEED_PER_CPU_KM=y
# CONFIG_CLEANCACHE is not set
# Executable file formats
CONFIG_BINFMT_ELF=y
# CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS is not set
# CONFIG_HAVE_AOUT is not set
# CONFIG_BINFMT_MISC is not set
# Bus Options
# CONFIG_PCI is not set
# CONFIG_PCI_DOMAINS is not set
# CONFIG_PCI_SYSCALL is not set
# CONFIG_ARCH_SUPPORTS_MSI is not set
CONFIG_NET=y
# Networking options
CONFIG_PACKET=y
CONFIG_UNIX=y
CONFIG_XFRM=y
# CONFIG_XFRM_USER is not set
# CONFIG_XFRM_SUB_POLICY is not set
# CONFIG_XFRM_MIGRATE is not set
# CONFIG_XFRM_STATISTICS is not set
# CONFIG_NET_KEY is not set
CONFIG_INET=y
# CONFIG_IP_MULTICAST is not set
# CONFIG_IP_ADVANCED_ROUTER is not set
CONFIG_IP_PNP=y
CONFIG_IP_PNP_DHCP=y
# CONFIG_IP_PNP_BOOTP is not set
# CONFIG_IP_PNP_RARP is not set
# CONFIG_NET_IPIP is not set
# CONFIG_NET_IPGRE_DEMUX is not set
# CONFIG_ARPD is not set
# CONFIG_SYN_COOKIES is not set
# CONFIG_INET_AH is not set
# CONFIG_INET_ESP is not set
# CONFIG_INET_IPCOMP is not set
# CONFIG_INET_XFRM_TUNNEL is not set
# CONFIG_INET_TUNNEL is not set
CONFIG_INET_XFRM_MODE_TRANSPORT=y
CONFIG_INET_XFRM_MODE_TUNNEL=y
CONFIG_INET_XFRM_MODE_BEET=y
# CONFIG_INET_LRO is not set
CONFIG_INET_DIAG=y
CONFIG_INET_TCP_DIAG=y
# CONFIG_TCP_CONG_ADVANCED is not set
CONFIG_TCP_CONG_CUBIC=y
CONFIG_DEFAULT_TCP_CONG="cubic"
# CONFIG_TCP_MD5SIG is not set
# CONFIG_IPV6 is not set
# CONFIG_NETWORK_SECMARK is not set
# CONFIG_NETWORK_PHY_TIMESTAMPING is not set
# CONFIG_NETFILTER is not set
# CONFIG_IP_DCCP is not set
# CONFIG_IP_SCTP is not set
# CONFIG_RDS is not set
# CONFIG_TIPC is not set
# CONFIG_ATM is not set
# CONFIG_L2TP is not set
# CONFIG_BRIDGE is not set
# CONFIG_NET_DSA is not set
# CONFIG_VLAN_8021Q is not set
# CONFIG_DECNET is not set
# CONFIG_LLC2 is not set
# CONFIG_IPX is not set
# CONFIG_ATALK is not set
# CONFIG_X25 is not set
# CONFIG_LAPB is not set
# CONFIG_ECONET is not set
# CONFIG_WAN_ROUTER is not set
# CONFIG_PHONET is not set
# CONFIG_IEEE802154 is not set
# CONFIG_NET_SCHED is not set
# CONFIG_DCB is not set
# CONFIG_BATMAN_ADV is not set
# Network testing
# CONFIG_NET_PKTGEN is not set
# CONFIG_HAMRADIO is not set
# CONFIG_CAN is not set
# CONFIG_IRDA is not set
# CONFIG_BT is not set
# CONFIG_AF_RXRPC is not set
CONFIG_WIRELESS=y
# CONFIG_CFG80211 is not set
# CONFIG_LIB80211 is not set
# CFG80211 needs to be enabled for MAC80211
# CONFIG_WIMAX is not set
# CONFIG_RFKILL is not set
# CONFIG_NET_9P is not set
# CONFIG_CAIF is not set
# CONFIG_CEPH_LIB is not set
# Device Drivers
# Generic Driver Options
CONFIG_STANDALONE=y
CONFIG_PREVENT_FIRMWARE_BUILD=y
CONFIG_FW_LOADER=y
CONFIG_FIRMWARE_IN_KERNEL=y
CONFIG_EXTRA_FIRMWARE=""
# CONFIG_SYS_HYPERVISOR is not set
# CONFIG_CONNECTOR is not set
# CONFIG_MTD is not set
CONFIG_DTC=y
CONFIG_OF=y
# Device Tree and Open Firmware support
CONFIG_PROC_DEVICETREE=y
CONFIG_OF_FLATTREE=y
CONFIG_OF_EARLY_FLATTREE=y
CONFIG_OF_ADDRESS=y
CONFIG_OF_IRQ=y
CONFIG_OF_DEVICE=y
CONFIG_OF_GPIO=y
CONFIG_OF_I2C=y
CONFIG_OF_NET=y
CONFIG_OF_SPI=y
CONFIG_OF_MDIO=y
# CONFIG_PARPORT is not set
CONFIG_BLK_DEV=y
# CONFIG_BLK_DEV_COW_COMMON is not set
# CONFIG_BLK_DEV_LOOP is not set
# DRBD disabled because PROC_FS, INET or CONNECTOR not selected
# CONFIG_BLK_DEV_NBD is not set
CONFIG_BLK_DEV_RAM=y
CONFIG_BLK_DEV_RAM_COUNT=16
CONFIG_BLK_DEV_RAM_SIZE=8192
# CONFIG_BLK_DEV_XIP is not set
# CONFIG_CDROM_PKTCDVD is not set
# CONFIG_ATA_OVER_ETH is not set
CONFIG_XILINX_SYSACE=y
# CONFIG_BLK_DEV_RBD is not set
CONFIG_MISC_DEVICES=y
# CONFIG_AD525X_DPOT is not set
# CONFIG_INTEL_MID_PTI is not set
# CONFIG_ICS932S401 is not set
# CONFIG_ENCLOSURE_SERVICES is not set
# CONFIG_APDS9802ALS is not set
# CONFIG_ISL29003 is not set
# CONFIG_ISL29020 is not set
# CONFIG_SENSORS_TSL2550 is not set
# CONFIG_SENSORS_BH1780 is not set
# CONFIG_SENSORS_BH1770 is not set
# CONFIG_SENSORS_APDS990X is not set
# CONFIG_HMC6352 is not set
# CONFIG_DS1682 is not set
# CONFIG_TI_DAC7512 is not set
# CONFIG_BMP085 is not set
# CONFIG_C2PORT is not set
# EEPROM support
# CONFIG_EEPROM_AT24 is not set
CONFIG_EEPROM_AT25=y
# CONFIG_EEPROM_LEGACY is not set
# CONFIG_EEPROM_MAX6875 is not set
# CONFIG_EEPROM_93CX6 is not set
# Texas Instruments shared transport line discipline
# CONFIG_TI_ST is not set
CONFIG_XILINX_DRIVERS=y
CONFIG_NEED_XILINX_LLDMA=y
# SCSI device support
CONFIG_SCSI_MOD=y
# CONFIG_RAID_ATTRS is not set
# CONFIG_SCSI is not set
# CONFIG_SCSI_DMA is not set
# CONFIG_SCSI_NETLINK is not set
# CONFIG_ATA is not set
# CONFIG_MD is not set
CONFIG_NETDEVICES=y
# CONFIG_DUMMY is not set
# CONFIG_BONDING is not set
# CONFIG_MACVLAN is not set
# CONFIG_EQUALIZER is not set
# CONFIG_TUN is not set
# CONFIG_VETH is not set
# CONFIG_MII is not set
CONFIG_PHYLIB=y
# MII PHY device drivers
# CONFIG_MARVELL_PHY is not set
# CONFIG_DAVICOM_PHY is not set
# CONFIG_QSEMI_PHY is not set
# CONFIG_LXT_PHY is not set
# CONFIG_CICADA_PHY is not set
# CONFIG_VITESSE_PHY is not set
# CONFIG_SMSC_PHY is not set
# CONFIG_BROADCOM_PHY is not set
# CONFIG_ICPLUS_PHY is not set
# CONFIG_REALTEK_PHY is not set
# CONFIG_NATIONAL_PHY is not set
# CONFIG_STE10XP is not set
# CONFIG_LSI_ET1011C_PHY is not set
# CONFIG_MICREL_PHY is not set
# CONFIG_FIXED_PHY is not set
# CONFIG_MDIO_BITBANG is not set
CONFIG_NET_ETHERNET=y
# CONFIG_ENC28J60 is not set
# CONFIG_ETHOC is not set
# CONFIG_DNET is not set
# CONFIG_IBM_NEW_EMAC_ZMII is not set
# CONFIG_IBM_NEW_EMAC_RGMII is not set
# CONFIG_IBM_NEW_EMAC_TAH is not set
# CONFIG_IBM_NEW_EMAC_EMAC4 is not set
# CONFIG_IBM_NEW_EMAC_NO_FLOW_CTRL is not set
# CONFIG_IBM_NEW_EMAC_MAL_CLR_ICINTSTAT is not set
# CONFIG_IBM_NEW_EMAC_MAL_COMMON_ERR is not set
# CONFIG_B44 is not set
# CONFIG_KS8851 is not set
# CONFIG_KS8851_MLL is not set
# CONFIG_XILINX_EMAC is not set
CONFIG_XILINX_EMACLITE=y
CONFIG_NETDEV_1000=y
# CONFIG_XILINX_LL_TEMAC is not set
# CONFIG_XILINX_AXI_ETHERNET is not set
# CONFIG_XILINX_TEMAC is not set
CONFIG_XILINX_LLTEMAC=y
# CONFIG_XILINX_LLTEMAC_MARVELL_88E1111_RGMII is not set
CONFIG_XILINX_LLTEMAC_MARVELL_88E1111_GMII=y
# CONFIG_XILINX_LLTEMAC_MARVELL_88E1111_MII is not set
# CONFIG_XILINX_LLTEMAC_NATIONAL_DP83865_GMII is not set
# CONFIG_STMMAC_ETH is not set
CONFIG_NETDEV_10000=y
CONFIG_WLAN=y
# CONFIG_HOSTAP is not set
# Enable WiMAX (Networking options) to see the WiMAX drivers
# CONFIG_WAN is not set
# CAIF transport drivers
# CONFIG_PPP is not set
# CONFIG_SLIP is not set
# CONFIG_NETCONSOLE is not set
# CONFIG_NETPOLL is not set
# CONFIG_NET_POLL_CONTROLLER is not set
# CONFIG_ISDN is not set
# CONFIG_PHONE is not set
# Input device support
# CONFIG_INPUT is not set
# Hardware I/O ports
# CONFIG_SERIO is not set
# CONFIG_GAMEPORT is not set
# Character devices
# CONFIG_VT is not set
CONFIG_UNIX98_PTYS=y
# CONFIG_DEVPTS_MULTIPLE_INSTANCES is not set
CONFIG_LEGACY_PTYS=y
CONFIG_LEGACY_PTY_COUNT=256
# CONFIG_SERIAL_NONSTANDARD is not set
# CONFIG_N_GSM is not set
# CONFIG_TRACE_SINK is not set
CONFIG_DEVKMEM=y
# Serial drivers
CONFIG_SERIAL_8250=y
CONFIG_SERIAL_8250_CONSOLE=y
CONFIG_SERIAL_8250_NR_UARTS=4
CONFIG_SERIAL_8250_RUNTIME_UARTS=4
# CONFIG_SERIAL_8250_EXTENDED is not set
# Non-8250 serial port support
# CONFIG_SERIAL_MAX3100 is not set
# CONFIG_SERIAL_MAX3107 is not set
CONFIG_SERIAL_UARTLITE=y
CONFIG_SERIAL_UARTLITE_CONSOLE=y
CONFIG_SERIAL_CORE=y
CONFIG_SERIAL_CORE_CONSOLE=y
CONFIG_SERIAL_OF_PLATFORM=y
# CONFIG_SERIAL_TIMBERDALE is not set
# CONFIG_SERIAL_ALTERA_JTAGUART is not set
# CONFIG_SERIAL_ALTERA_UART is not set
# CONFIG_SERIAL_IFX6X60 is not set
# CONFIG_SERIAL_XILINX_PS_UART is not set
# CONFIG_TTY_PRINTK is not set
# CONFIG_IPMI_HANDLER is not set
# CONFIG_HW_RANDOM is not set
# CONFIG_RTC is not set
# CONFIG_GEN_RTC is not set
# CONFIG_XILINX_HWICAP is not set
# CONFIG_R3964 is not set
# CONFIG_RAW_DRIVER is not set
# CONFIG_TCG_TPM is not set
# CONFIG_RAMOOPS is not set
CONFIG_I2C=y
CONFIG_I2C_BOARDINFO=y
CONFIG_I2C_COMPAT=y
CONFIG_I2C_CHARDEV=y
# CONFIG_I2C_MUX is not set
# CONFIG_I2C_HELPER_AUTO is not set
# CONFIG_I2C_SMBUS is not set
# I2C Algorithms
# CONFIG_I2C_ALGOBIT is not set
# CONFIG_I2C_ALGOPCF is not set
# CONFIG_I2C_ALGOPCA is not set
CONFIG_XILINX_IIC=y
# I2C Hardware Bus support
# I2C system bus drivers (mostly embedded / system-on-chip)
# CONFIG_I2C_GPIO is not set
# CONFIG_I2C_OCORES is not set
# CONFIG_I2C_PCA_PLATFORM is not set
# CONFIG_I2C_PXA_PCI is not set
# CONFIG_I2C_SIMTEC is not set
# CONFIG_I2C_XILINX is not set
# External I2C/SMBus adapter drivers
# CONFIG_I2C_PARPORT_LIGHT is not set
# CONFIG_I2C_TAOS_EVM is not set
# Other I2C/SMBus bus drivers
# CONFIG_I2C_STUB is not set
# CONFIG_I2C_DEBUG_CORE is not set
# CONFIG_I2C_DEBUG_ALGO is not set
# CONFIG_I2C_DEBUG_BUS is not set
CONFIG_SPI=y
CONFIG_SPI_MASTER=y
# SPI Master Controller Drivers
# CONFIG_SPI_ALTERA is not set
CONFIG_SPI_BITBANG=y
# CONFIG_SPI_GPIO is not set
# CONFIG_SPI_OC_TINY is not set
# CONFIG_SPI_PXA2XX_PCI is not set
CONFIG_SPI_XILINX=y
# CONFIG_SPI_DESIGNWARE is not set
# SPI Protocol Masters
# CONFIG_SPI_SPIDEV is not set
# CONFIG_SPI_TLE62X0 is not set
# PPS support
# CONFIG_PPS is not set
# PPS generators support
# PTP clock support
# Enable Device Drivers -> PPS to see the PTP clock options.
CONFIG_ARCH_WANT_OPTIONAL_GPIOLIB=y
CONFIG_GPIOLIB=y
CONFIG_GPIO_SYSFS=y
# Memory mapped GPIO drivers:
# CONFIG_GPIO_BASIC_MMIO is not set
# CONFIG_GPIO_IT8761E is not set
CONFIG_GPIO_XILINX=y
# I2C GPIO expanders:
# CONFIG_GPIO_MAX7300 is not set
# CONFIG_GPIO_MAX732X is not set
# CONFIG_GPIO_PCA953X is not set
# CONFIG_GPIO_PCF857X is not set
# CONFIG_GPIO_SX150X is not set
# CONFIG_GPIO_ADP5588 is not set
# PCI GPIO expanders:
# SPI GPIO expanders:
# CONFIG_GPIO_MAX7301 is not set
# CONFIG_GPIO_MCP23S08 is not set
# CONFIG_GPIO_MC33880 is not set
# CONFIG_GPIO_74X164 is not set
# AC97 GPIO expanders:
# MODULbus GPIO expanders:
# CONFIG_W1 is not set
# CONFIG_POWER_SUPPLY is not set
# CONFIG_HWMON is not set
# CONFIG_THERMAL is not set
# CONFIG_WATCHDOG is not set
CONFIG_SSB_POSSIBLE=y
# Sonics Silicon Backplane
# CONFIG_SSB is not set
CONFIG_BCMA_POSSIBLE=y
# Broadcom specific AMBA
# CONFIG_BCMA is not set
CONFIG_MFD_SUPPORT=y
# CONFIG_MFD_CORE is not set
# CONFIG_MFD_88PM860X is not set
# CONFIG_MFD_SM501 is not set
# CONFIG_HTC_PASIC3 is not set
# CONFIG_HTC_I2CPLD is not set
# CONFIG_TPS6105X is not set
# CONFIG_TPS65010 is not set
# CONFIG_TPS6507X is not set
# CONFIG_MFD_TPS6586X is not set
# CONFIG_TWL4030_CORE is not set
# CONFIG_MFD_STMPE is not set
# CONFIG_MFD_TC3589X is not set
# CONFIG_MFD_TMIO is not set
# CONFIG_PMIC_DA903X is not set
# CONFIG_PMIC_ADP5520 is not set
# CONFIG_MFD_MAX8925 is not set
# CONFIG_MFD_MAX8997 is not set
# CONFIG_MFD_MAX8998 is not set
# CONFIG_MFD_WM8400 is not set
# CONFIG_MFD_WM831X_I2C is not set
# CONFIG_MFD_WM831X_SPI is not set
# CONFIG_MFD_WM8350_I2C is not set
# CONFIG_MFD_WM8994 is not set
# CONFIG_MFD_PCF50633 is not set
# CONFIG_MFD_MC13XXX is not set
# CONFIG_ABX500_CORE is not set
# CONFIG_EZX_PCAP is not set
# CONFIG_MFD_WL1273_CORE is not set
# CONFIG_MFD_TPS65910 is not set
# CONFIG_REGULATOR is not set
# CONFIG_MEDIA_SUPPORT is not set
# Graphics support
# CONFIG_DRM is not set
# CONFIG_VGASTATE is not set
# CONFIG_VIDEO_OUTPUT_CONTROL is not set
# CONFIG_FB is not set
# CONFIG_BACKLIGHT_LCD_SUPPORT is not set
# Display device support
# CONFIG_DISPLAY_SUPPORT is not set
# CONFIG_SOUND is not set
# CONFIG_USB_SUPPORT is not set
# CONFIG_MMC is not set
# CONFIG_MEMSTICK is not set
# CONFIG_NEW_LEDS is not set
# CONFIG_NFC_DEVICES is not set
# CONFIG_ACCESSIBILITY is not set
# CONFIG_RTC_CLASS is not set
# CONFIG_DMADEVICES is not set
# CONFIG_AUXDISPLAY is not set
CONFIG_XILINX_EDK=y
# CONFIG_XILINX_LLDMA_USE_DCR is not set
# CONFIG_UIO is not set
# CONFIG_STAGING is not set
# File systems
CONFIG_EXT2_FS=y
# CONFIG_EXT2_FS_XATTR is not set
# CONFIG_EXT2_FS_XIP is not set
CONFIG_EXT3_FS=y
# CONFIG_EXT3_DEFAULTS_TO_ORDERED is not set
CONFIG_EXT3_FS_XATTR=y
# CONFIG_EXT3_FS_POSIX_ACL is not set
# CONFIG_EXT3_FS_SECURITY is not set
# CONFIG_EXT4_FS is not set
CONFIG_JBD=y
CONFIG_FS_MBCACHE=y
# CONFIG_REISERFS_FS is not set
# CONFIG_JFS_FS is not set
# CONFIG_XFS_FS is not set
# CONFIG_GFS2_FS is not set
# CONFIG_BTRFS_FS is not set
# CONFIG_NILFS2_FS is not set
# CONFIG_FS_POSIX_ACL is not set
CONFIG_FILE_LOCKING=y
CONFIG_FSNOTIFY=y
# CONFIG_DNOTIFY is not set
CONFIG_INOTIFY_USER=y
# CONFIG_FANOTIFY is not set
# CONFIG_QUOTA is not set
# CONFIG_QUOTACTL is not set
# CONFIG_AUTOFS4_FS is not set
# CONFIG_FUSE_FS is not set
# Caches
# CONFIG_FSCACHE is not set
# CD-ROM/DVD Filesystems
# CONFIG_ISO9660_FS is not set
# CONFIG_UDF_FS is not set
# DOS/FAT/NT Filesystems
# CONFIG_MSDOS_FS is not set
# CONFIG_VFAT_FS is not set
# CONFIG_NTFS_FS is not set
# Pseudo filesystems
CONFIG_PROC_FS=y
# CONFIG_PROC_KCORE is not set
CONFIG_PROC_SYSCTL=y
CONFIG_PROC_PAGE_MONITOR=y
CONFIG_SYSFS=y
# CONFIG_HUGETLB_PAGE is not set
# CONFIG_CONFIGFS_FS is not set
CONFIG_MISC_FILESYSTEMS=y
# CONFIG_ADFS_FS is not set
# CONFIG_AFFS_FS is not set
# CONFIG_HFS_FS is not set
# CONFIG_HFSPLUS_FS is not set
# CONFIG_BEFS_FS is not set
# CONFIG_BFS_FS is not set
# CONFIG_EFS_FS is not set
# CONFIG_LOGFS is not set
# CONFIG_CRAMFS is not set
# CONFIG_SQUASHFS is not set
# CONFIG_VXFS_FS is not set
# CONFIG_MINIX_FS is not set
# CONFIG_MINIX_FS_NATIVE_ENDIAN is not set
# CONFIG_OMFS_FS is not set
# CONFIG_HPFS_FS is not set
# CONFIG_QNX4FS_FS is not set
# CONFIG_ROMFS_FS is not set
# CONFIG_PSTORE is not set
# CONFIG_SYSV_FS is not set
# CONFIG_UFS_FS is not set
CONFIG_NETWORK_FILESYSTEMS=y
CONFIG_NFS_FS=y
CONFIG_NFS_V3=y
# CONFIG_NFS_V3_ACL is not set
# CONFIG_NFS_V4 is not set
CONFIG_ROOT_NFS=y
# CONFIG_NFSD is not set
CONFIG_LOCKD=y
CONFIG_LOCKD_V4=y
CONFIG_NFS_COMMON=y
CONFIG_SUNRPC=y
# CONFIG_CEPH_FS is not set
CONFIG_CIFS=y
CONFIG_CIFS_STATS=y
CONFIG_CIFS_STATS2=y
# CONFIG_CIFS_WEAK_PW_HASH is not set
# CONFIG_CIFS_XATTR is not set
# CONFIG_CIFS_DEBUG2 is not set
# CONFIG_NCP_FS is not set
# CONFIG_CODA_FS is not set
# CONFIG_AFS_FS is not set
# Partition Types
CONFIG_PARTITION_ADVANCED=y
# CONFIG_ACORN_PARTITION is not set
# CONFIG_OSF_PARTITION is not set
# CONFIG_AMIGA_PARTITION is not set
# CONFIG_ATARI_PARTITION is not set
# CONFIG_MAC_PARTITION is not set
CONFIG_MSDOS_PARTITION=y
# CONFIG_BSD_DISKLABEL is not set
# CONFIG_MINIX_SUBPARTITION is not set
# CONFIG_SOLARIS_X86_PARTITION is not set
# CONFIG_UNIXWARE_DISKLABEL is not set
# CONFIG_LDM_PARTITION is not set
# CONFIG_SGI_PARTITION is not set
# CONFIG_ULTRIX_PARTITION is not set
# CONFIG_SUN_PARTITION is not set
# CONFIG_KARMA_PARTITION is not set
# CONFIG_EFI_PARTITION is not set
# CONFIG_SYSV68_PARTITION is not set
CONFIG_NLS=y
CONFIG_NLS_DEFAULT="iso8859-1"
# CONFIG_NLS_CODEPAGE_437 is not set
# CONFIG_NLS_CODEPAGE_737 is not set
# CONFIG_NLS_CODEPAGE_775 is not set
# CONFIG_NLS_CODEPAGE_850 is not set
# CONFIG_NLS_CODEPAGE_852 is not set
# CONFIG_NLS_CODEPAGE_855 is not set
# CONFIG_NLS_CODEPAGE_857 is not set
# CONFIG_NLS_CODEPAGE_860 is not set
# CONFIG_NLS_CODEPAGE_861 is not set
# CONFIG_NLS_CODEPAGE_862 is not set
# CONFIG_NLS_CODEPAGE_863 is not set
# CONFIG_NLS_CODEPAGE_864 is not set
# CONFIG_NLS_CODEPAGE_865 is not set
# CONFIG_NLS_CODEPAGE_866 is not set
# CONFIG_NLS_CODEPAGE_869 is not set
# CONFIG_NLS_CODEPAGE_936 is not set
# CONFIG_NLS_CODEPAGE_950 is not set
# CONFIG_NLS_CODEPAGE_932 is not set
# CONFIG_NLS_CODEPAGE_949 is not set
# CONFIG_NLS_CODEPAGE_874 is not set
# CONFIG_NLS_ISO8859_8 is not set
# CONFIG_NLS_CODEPAGE_1250 is not set
# CONFIG_NLS_CODEPAGE_1251 is not set
# CONFIG_NLS_ASCII is not set
# CONFIG_NLS_ISO8859_1 is not set
# CONFIG_NLS_ISO8859_2 is not set
# CONFIG_NLS_ISO8859_3 is not set
# CONFIG_NLS_ISO8859_4 is not set
# CONFIG_NLS_ISO8859_5 is not set
# CONFIG_NLS_ISO8859_6 is not set
# CONFIG_NLS_ISO8859_7 is not set
# CONFIG_NLS_ISO8859_9 is not set
# CONFIG_NLS_ISO8859_13 is not set
# CONFIG_NLS_ISO8859_14 is not set
# CONFIG_NLS_ISO8859_15 is not set
# CONFIG_NLS_KOI8_R is not set
# CONFIG_NLS_KOI8_U is not set
# CONFIG_NLS_UTF8 is not set
# Kernel hacking
CONFIG_TRACE_IRQFLAGS_SUPPORT=y
# CONFIG_PRINTK_TIME is not set
CONFIG_DEFAULT_MESSAGE_LOGLEVEL=4
CONFIG_ENABLE_WARN_DEPRECATED=y
CONFIG_ENABLE_MUST_CHECK=y
CONFIG_FRAME_WARN=1024
# CONFIG_MAGIC_SYSRQ is not set
# CONFIG_STRIP_ASM_SYMS is not set
# CONFIG_UNUSED_SYMBOLS is not set
# CONFIG_DEBUG_FS is not set
# CONFIG_HEADERS_CHECK is not set
# CONFIG_DEBUG_SECTION_MISMATCH is not set
# CONFIG_DEBUG_KERNEL is not set
# CONFIG_HARDLOCKUP_DETECTOR is not set
# CONFIG_SPARSE_RCU_POINTER is not set
# CONFIG_DEBUG_MEMORY_INIT is not set
# CONFIG_SYSCTL_SYSCALL_CHECK is not set
CONFIG_HAVE_FUNCTION_TRACER=y
CONFIG_HAVE_FUNCTION_GRAPH_TRACER=y
CONFIG_HAVE_FUNCTION_TRACE_MCOUNT_TEST=y
CONFIG_HAVE_DYNAMIC_FTRACE=y
CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y
CONFIG_TRACING_SUPPORT=y
# CONFIG_FTRACE is not set
# CONFIG_DMA_API_DEBUG is not set
# CONFIG_ATOMIC64_SELFTEST is not set
# CONFIG_SAMPLES is not set
CONFIG_HAVE_ARCH_KGDB=y
# CONFIG_TEST_KSTRTOX is not set
CONFIG_EARLY_PRINTK=y
# CONFIG_HEART_BEAT is not set
# Security options
# CONFIG_KEYS is not set
# CONFIG_SECURITY_DMESG_RESTRICT is not set
# CONFIG_SECURITY is not set
# CONFIG_SECURITYFS is not set
CONFIG_DEFAULT_SECURITY_DAC=y
CONFIG_DEFAULT_SECURITY=""
CONFIG_CRYPTO=y
# Crypto core or helper
CONFIG_CRYPTO_ALGAPI=y
CONFIG_CRYPTO_ALGAPI2=y
CONFIG_CRYPTO_AEAD2=y
CONFIG_CRYPTO_BLKCIPHER=y
CONFIG_CRYPTO_BLKCIPHER2=y
CONFIG_CRYPTO_HASH=y
CONFIG_CRYPTO_HASH2=y
CONFIG_CRYPTO_RNG2=y
CONFIG_CRYPTO_PCOMP2=y
CONFIG_CRYPTO_MANAGER=y
CONFIG_CRYPTO_MANAGER2=y
CONFIG_CRYPTO_MANAGER_DISABLE_TESTS=y
# CONFIG_CRYPTO_GF128MUL is not set
# CONFIG_CRYPTO_NULL is not set
CONFIG_CRYPTO_WORKQUEUE=y
# CONFIG_CRYPTO_CRYPTD is not set
# CONFIG_CRYPTO_AUTHENC is not set
# CONFIG_CRYPTO_TEST is not set
# Authenticated Encryption with Associated Data
# CONFIG_CRYPTO_CCM is not set
# CONFIG_CRYPTO_GCM is not set
# CONFIG_CRYPTO_SEQIV is not set
# Block modes
# CONFIG_CRYPTO_CBC is not set
# CONFIG_CRYPTO_CTR is not set
# CONFIG_CRYPTO_CTS is not set
CONFIG_CRYPTO_ECB=y
# CONFIG_CRYPTO_LRW is not set
# CONFIG_CRYPTO_PCBC is not set
# CONFIG_CRYPTO_XTS is not set
# Hash modes
CONFIG_CRYPTO_HMAC=y
# CONFIG_CRYPTO_XCBC is not set
# CONFIG_CRYPTO_VMAC is not set
# Digest
# CONFIG_CRYPTO_CRC32C is not set
# CONFIG_CRYPTO_GHASH is not set
CONFIG_CRYPTO_MD4=y
CONFIG_CRYPTO_MD5=y
# CONFIG_CRYPTO_MICHAEL_MIC is not set
# CONFIG_CRYPTO_RMD128 is not set
# CONFIG_CRYPTO_RMD160 is not set
# CONFIG_CRYPTO_RMD256 is not set
# CONFIG_CRYPTO_RMD320 is not set
# CONFIG_CRYPTO_SHA1 is not set
# CONFIG_CRYPTO_SHA256 is not set
# CONFIG_CRYPTO_SHA512 is not set
# CONFIG_CRYPTO_TGR192 is not set
# CONFIG_CRYPTO_WP512 is not set
# Ciphers
# CONFIG_CRYPTO_AES is not set
# CONFIG_CRYPTO_ANUBIS is not set
CONFIG_CRYPTO_ARC4=y
# CONFIG_CRYPTO_BLOWFISH is not set
# CONFIG_CRYPTO_CAMELLIA is not set
# CONFIG_CRYPTO_CAST5 is not set
# CONFIG_CRYPTO_CAST6 is not set
CONFIG_CRYPTO_DES=y
# CONFIG_CRYPTO_FCRYPT is not set
# CONFIG_CRYPTO_KHAZAD is not set
# CONFIG_CRYPTO_SALSA20 is not set
# CONFIG_CRYPTO_SEED is not set
# CONFIG_CRYPTO_SERPENT is not set
# CONFIG_CRYPTO_TEA is not set
# CONFIG_CRYPTO_TWOFISH is not set
# Compression
# CONFIG_CRYPTO_DEFLATE is not set
# CONFIG_CRYPTO_ZLIB is not set
# CONFIG_CRYPTO_LZO is not set
# Random Number Generation
# CONFIG_CRYPTO_ANSI_CPRNG is not set
# CONFIG_CRYPTO_USER_API_HASH is not set
# CONFIG_CRYPTO_USER_API_SKCIPHER is not set
CONFIG_CRYPTO_HW=y
# CONFIG_BINARY_PRINTF is not set
# Library routines
CONFIG_BITREVERSE=y
# CONFIG_CRC_CCITT is not set
# CONFIG_CRC16 is not set
# CONFIG_CRC_T10DIF is not set
# CONFIG_CRC_ITU_T is not set
CONFIG_CRC32=y
# CONFIG_CRC7 is not set
# CONFIG_LIBCRC32C is not set
CONFIG_ZLIB_INFLATE=y
# CONFIG_XZ_DEC is not set
# CONFIG_XZ_DEC_BCJ is not set
CONFIG_DECOMPRESS_GZIP=y
CONFIG_HAS_IOMEM=y
CONFIG_HAS_IOPORT=y
CONFIG_HAS_DMA=y
CONFIG_NLATTR=y
# CONFIG_AVERAGE is not set
