Linux Cadence MMSIM61 Porblem (mount new media,Base IC610 P/N 356-70352-0701 CDROM #)
happsky
Full Member level 1
With a windows like this :
(mount new media,Base IC610 P/N 356-70352-0701 CDROM1 #)
what should I do ,I made the path point the to mmsim61 CDROM1,but no work .
how can i get it right and which buttom should i click?
can you type the following command and paste the output here:
mount
Hi happsky!
I think you'd better copy MMSIM source to your hard drive.
Hello, I have the same problem with you. I just want to find out how to solve it. Please help, thanks!
I know a long time has passed, but did you work it out finally. I have the same problem with you, and I don't know what to do. Please help, thank you!
fuyi@fuyi-laptop:~$ mount
/dev/sda9 on / type ext4 (rw,errors=remount-ro)
proc on /proc type proc (rw,noexec,nosuid,nodev)
none on /sys type sysfs (rw,noexec,nosuid,nodev)
none on /sys/fs/fuse/connections type fusectl (rw)
none on /sys/kernel/debug type debugfs (rw)
none on /sys/kernel/security type securityfs (rw)
none on /dev type devtmpfs (rw,mode=0755)
none on /dev/pts type devpts (rw,noexec,nosuid,gid=5,mode=0620)
none on /dev/shm type tmpfs (rw,nosuid,nodev)
none on /var/run type tmpfs (rw,nosuid,mode=0755)
none on /var/lock type tmpfs (rw,noexec,nosuid,nodev)
none on /lib/init/rw type tmpfs (rw,nosuid,mode=0755)
rpc_pipefs on /var/lib/nfs/rpc_pipefs type rpc_pipefs (rw)
nfsd on /proc/fs/nfsd type nfsd (rw)
binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,noexec,nosuid,nodev)
gvfs-fuse-daemon on /home/fuyi/.gvfs type fuse.gvfs-fuse-daemon (rw,nosuid,nodev,user=fuyi)
