Eugen_E
Full Member level 6
Hello,
I'm using a regulator with the schematic posted in the image attached, powered from a 30V source with 20000uF filter caps that can probably deliver more than 20A for short periods.
Unfortunately, the pass transistor blows instantly on short circuit. Q2 should limit the output current to 6-7A, but it seems it acts too slow, or the MOSFET needs a special type of protection like current foldback.
What kind of protection circuit would you recommend, so that the regulator can withstand accidental shortcircuit for 1-2 seconds?
Thanks
Thanks
