Linear regulator supplied from noise line.
ivenzar
Member level 2
Hello,
If a 5v linear regulator is supplied by a 12 volts noisy line (the one that drives the mosfet gates), the regulator output will pick up that noise or it will be removed?
Thanks
Greetings
Ivenzar.
the output noise depends on the filter components in the regulator.
1.- Where can I find ripple rejection? https://www.onsemi.com/pub_link/Collateral/NCV4269-D.PDF
2.-If ripple rejection is OK. WHat about the noisy ground? Returns driving currents are on same ground as linear regulator. Will it affect? or will I have a clean regulated 5v line?
