library manger setting and undo setting
wccheng
Full Member level 5
Dear all,
How could I set my icfb setting in order to open the library manger in automatically when I firstly open my icfb? Moreover, how could I set to have undo 10 times? Since I need to set it every time after I re-open icfb.
Thanks
wccheng
i just found that setting undo times, select option on CIW, then select the User Preference, Undo Limit is the undo times, and you can set it in ~/.cdsenv to auto load it using"ui undoLevel int 10"
