Libraries in keil c with 8051
#MAAM#
Full Member level 2
Full Member level 2
Egypt
Hi guys
i need any library in keil c with 8051 such as LCD,Keypad,...............etc. To help me in programming with 8051. thanks in advance
hi
or search on the net and do necessary changes
ml
Concernig LCD you posted, need give more detail :
> Character type / Graphic type ?
> Brand Model affects driver commands, because there are a lot of chipsets ( Hitashi, Epson, Samsung )
or you can easily use MikroC for 8051 if you want libraries
thank you.
keil does not have inbuilt libraries for peripherals.. the user has to create it himself...
thank you for this illustration
hi
ml
thank you
i will clear what i need
i will try
_________________________________________________________________________________________________________________________________________________
for all guys
i need thing such as stock in libraries in keil, so when i need any code i refer to it. thanks in advance
you can del\velop codes with different header files example
for LCD routine develop lcd_init(), lcd_delay(), lcd_clear(), lcd_data
for i2c routine develop i2c_start(), I2c_write(), i2c_read(), i2c_ack(), i2c_stop() etc like this
so you can refer this anytime and add it to any program you want...
but i need the source code of this libraries.
You did not answered the fundamental question I posted.
How can we know exacly what you want ?
You must help us to we help you.
