LG monitor switches off after 1 or 2 hours
mamhosney
Junior Member level 1
lg monitor beeping
my LG display work well for a period of time then after about one or two hour it switched off by itself can any body help me please ...
thanks.
Re: LG monitor problem
right click on your desktop
click properties---> screen saver ---> energy saving settings
thanks ,but i don't think the problem here
i think it from my CRT which it may be low emission
so,the monitor turned off after a period of time
is that correct or there is another problem
May be you're right
as for my monitor ( it's OLD ) it sometimes goes black when the weather is too hot ( if I forget to load the air-conditioner or even a fan appointed directly to the monitor )
while it works good in good weather
how is model ?
if switch power button ( off/on) what happen?
You must look the schematic and service manual or etc following site:
www.eserviceinfo.com Ok?
Best regards.
ta2ctp
thanks i will check the manual and reply if i find the problem or not
Verify the supply voltage for the CRT.
Also for video stage.
Please use the oscilloscope.
Most of the time ist an soldering problem. If you turn of the power (remove powercord) and look ad the print for contacts wich are broken. These are most of the time around the FBT (black coil whit red and white cables to the tube) BE CAREFULL HIGH VOLTAGE.
Eppieelco
i have checked most links for my monitor manual ,but i didn't find it
if any one find LG 440si Manual please send to me ...'
thanks for all
I had the same problem, I suggest you, make a call for the company and ask them, if no help! just take it to the their service support and they check it!
I had the same prob, and finally I changed the monitor.
LG monitor problem
i have NEC-FE770 17" FLAT after some time when load of high resolution like 3d game . It produce sound like some slow beeping regularly after restart it work fine . This may some thing is weak?how can i solve this problem?
