Matrix drivers use either Common Anode Mux for "Y" LED column drivers and "X" Cathode row drivers or visa versa. to select LED in raster mode.
{ For bonus points design a 3D display using XYZ and control from PC USB port. with serial bit stream for each frame times Z frames using 1W LEDs @ $2~5/W }
Drivers must be able to handle Y x current for each LED running at 1/Y duty cycle. Estimate ESR of LED by characterization on scope with pulsed ramp from scope to control V-I test jig and use CH1 CH2 on scope to see results... in white..
Learn the Zener voltage and ESR for every LED type of interest. e.g. White Threshold ~ 2.65V and ESR = 50mΩ Typ for 10W LED and 5Ω for 100mΩ LED
Better to use constant current source drivers since V tolerance is low <0.05V within same batch but +/-0.2V to 0.3 batch to batch depending on current or ESR tolerance.
ESR tolerance is good within one batch after sorting form vendor but may be poor batch-batch unless specified.
Start small and "master" Constant current source and Average current source with one LED to see results of flicker and effective loss of efficiency from driving at higher MUX current and thus more loss, thermal rise also affects efficiency from ESR and efficacy of (LM/W).
For small matrix examine design signals of this.
https://www.vishay.com/product?docid=37084
Buy sample and test.
For extra bonus points make your own 3D LED display for entertainment purposes using RGB 5mm reel x 5m ($15 in volume) and modify tracks for selective control rather than parallel string.
For simple solution, use your favorite search engine.
I hope one of these ideas has inspired you to think outside the box and then learn what you need to learn.
If it were me , I would make like a TV using LCD driver chip with sample & hold caps to store charge like LCD to drive LED.. Consider using PWM for driving input of Column drivers to address each pixel using VGA signals or QVGA signals 320x160 with appropriate TV sync and matrix driver chips. But you may need to learn Altera or xilinx design to do this in 2 mos.
It all depends on how much you want to invest in learning & doing.
