tshwary
hi,
i have designed power supply with out parallel with zener diode of 5.1v,i need to put led for indating that there is load connected but i cant put it series with load since i really need 5.1v and putting series with load may cause a problem since i will no longer get maximum current since the more my load draw lot of current the voltage will decrease accross load since will be droping on led,
May you pleased help me with simple circuit i can put on output of my supply to show that load is connected and is not connected.
