Led Matrix Scroll UP and DOWN
cuber18
//PIC 8char dotmatrix, switchable to static-scrolling
//prg lenght 1077 words, made by zuisti, 29.08.2007
//for a simple and fast PROTEUS simulation I am not using line drivers !
#define COMMON_CATHODE
#define BUFFERSIZE 56
//max. 54 chars (and 2 gap space) for scrolling message
char buffer[BUFFERSIZE]; //display buffer: 8 chars + 2 spaces(gap for scrolling)
char FirstPos, NextPos, CharCnt, ScrollTime;
char mode, scrollcnt, charnum, linenum, pattern;
char *ptr, *startptr, *endptr;
char data1;
#include "bitmap.h"
//pos/speed switch inputs: PORTB<6:3> ;RB2 = SW_1 , sum value *8 !!
#define SPEEDMAX 10
//Mode switch input: PORTA.4 ;RA4   (0: scrolling, 1: static)
#define STATICMODE Porta.F4
//checked at start only
//Line decoder outputs: PORTA<2:0> ;RA0 = LSB
#define DisableLines PORTA = 0b0111  //all 1, decoder outputs are active low
//Clock  output: PORTB.0    ;RB0
//Data   output: PORTB.7    ;RB7
//Store  output: PORTA.3  (RA3), positive clock for shiftregs output storage
#define StorePulse PORTA.F3 = 1; PORTA.F3 = 0
//setup for positive pulses
#define PinInits      PORTA.F3 = 0; PORTB.F0 = 0; PORTB.F7 = 0
ClockoutPatternBit(X): Data = pattern.FX followed by an positive clock pulse
I am using here (too) a little asm, this is much shorter as the pure C
#define ClockoutPatternBit(X) asm { btfsc _pattern, X }; \
        asm { bsf PORTB, 7 }; \
        PORTB.F0 = 1; PORTB.F0 = 0; \
        PORTB.F7 = 0
//RX      input: PORTB.1    ;RB1
//this is used in IT
void DisplayClear(void) {
       DisableLines;
        CharCnt = BUFFERSIZE;   //init the display buffer with zeroes
        do
                buffer[--CharCnt] = 0;
        while ( CharCnt );
        --CharCnt;         //= 255, the first received char increments it to zero
        ptr = startptr = buffer;
void interrupt() {
        if ( RCREG < 0x20 ) {
                if ( RCREG == 0x0D )
                        DisplayClear();
        else if ( ++CharCnt < NextPos && CharCnt >= Firstpos ) {
                if ( RCREG > 0x7f )
                        RCREG = '?';
                *((char *)(buffer + (short)(CharCnt-FirstPos))) = RCREG - 0x20;
void GetPatternAndOut() {
#ifdef COMMON_CATHODE
        pattern = ~(bitmap[ (*ptr << 3)+ linenum ]);
#else
        pattern = bitmap[ (*ptr << 3)+ linenum ];
#endif
        ClockoutPatternBit(4);
        ClockoutPatternBit(3);
        ClockoutPatternBit(2);
        ClockoutPatternBit(1);
        ClockoutPatternBit(0);
void DisplayLine(void) {
        DisableLines;
        StorePulse;
        PORTA = linenum;
        Delay_us(400);
void HW_Init(void) {
        CMCON = 0b00000111; // switch off comparators
        TRISA = 0b10110000; // 7, 5 and 4 PORTA pins are inputs
// Initialize USART module for receive (rx) only:
        TXSTA.BRGH = 1;        SPBRG = 25;        //9600 Bd at 4 M clock
        RCSTA = 0b10010000;        // 8 bit, no parity
        asm {MOVF        RCREG, 0}; asm {MOVF        RCREG, 0};        //empty rx fifo in asm (short)
        TRISB = 0b01111110;        // only PORTB.0 and PORTB.7 are outputs
void main(void) {
        HW_Init();
        PinInits;
        DisplayClear();
        TRISD = 0x00;
       if ( !( mode = (char) STATICMODE ) ) { // 0 = scrolling mode
                FirstPos = 0;              //FirstPos
               NextPos = BUFFERSIZE;        //NextPos
               scrollcnt = 0;
               ScrollTime = SPEEDMAX;
        else {       //static mode
                NextPos =  FirstPos + 8;
  startptr = buffer;
  endptr = buffer + BUFFERSIZE;
        INTCON = 0xC0; PIE1 = 0x20;                                        //enable global ITs and RX it
        for ( ; ; ) { // main loop forever
                //scrolling mode (mode = 0) ?
                if ( !mode && ++scrollcnt == ScrollTime ) {
                        scrollcnt = 0;
                        ScrollTime = SPEEDMAX;   //check the speed sw again
                        //for a gap
                        INTCON = 0;                                        //disable IT
                        if ( CharCnt < (BUFFERSIZE - 3) && startptr < ( buffer + CharCnt + 2 ) )
                                endptr = buffer + CharCnt + 3;
                        INTCON = 0xC0;                        //enable IT
                        if ( ++startptr == endptr )
                                 startptr = buffer;
                        DisableLines;
                linenum = 7;
                do {
                        --linenum;
                        ptr = startptr;
                        charnum = 8;
                        do {
                                GetPatternAndOut();
                                //++charnum;
                                if (++ptr == endptr )
                                        ptr = buffer;
                        } while (--charnum);
                       DisplayLine();
                } while ( linenum );
        } // end loop
here is the code i want to revised.. i want this code to scroll up and down and also scroll to right... im newbie to this code.. can someone help me with this.. thanks..
btw im using cathode rows and anode columns.. im using 74ls154 in my rows and 74hc595 in my columns.. my pixels is 10x40..
