LED indication problem
yviswanathbe
Full Member level 4
Full Member level 4
I need a circuit of LED indication.
My Voltage source(Battery) is 10 to 160Vdc. When ever the source is connected i need to show a LED for indication.
Can any body suggest me any idea.
Thanks and Regards,
Viswanath
You can use something similar to this:
Remember to take into consideration the power loss in the resistor and in the transistor.
Hope this helps.
Tahmid.
Hi Tahmid,
Thanks for sharing the circuit.
I have done in a different way.But my circuit needs auxiliary power supply. When i try to derive it from the battery, the circuit draws more current. that shouldn't happen in my case.
Your circuit seems to be working perfect. I tried in simulation.
Thanks again for the circuit.
Regards,
Viswanath
