panneerrajan
- Joined
- Jul 9, 2013
- Messages
- 38
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 6
- Location
- Trivandrum
- Activity points
- 350
I need to drive LED by using PNP Transistor.
For that PNP Transistor - Emitter connect to VCC OR Collector connect to VCC?
Please find attached schematic for your reference
Please explain both method difference and when (which application) we need to use Emitter connect to VCC and Collector connect to VCC?
Current Flow:
PNP Transistor is -> Emitter to Collector
NPN Transistor is -> Collector to Emitter
So that PNP Transistor, we should connect Emitter as VCC?
Please explain and provide your suggestion
Thank You
Rajan
Current Flow:
Thank You
Rajan
