jfhsu
Newbie level 2
- Joined
- Apr 10, 2014
- Messages
- 2
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 23
Hi All,
Instead of using commercial variable power supplies, I tried to build a simple variable current source for a LED. However, LEDs kept burning out on me and left me puzzled. The circuit diagram is attached. Any hint will be much appreciated. Thanks in advance.
Problem seen:
When replacing the LED with simple amp meter, the current reads what I expected it to be. But when I just connected the LED with the BNC connector, there was an initial burst of light, and then ... the LED is dead.
Almost identical problem happened when I simply used a 18V supply and put a LED and a power resistor in series. Initial burst and that killed the LED, though the max current the circuit can draw is no where near the current rating.
Even a Schottky diodo, a resistor and a capacitor were added in parallel to the LED to protect from reverse voltage (if any), I still saw the initial deadly burst.
Again, any idea will be a great help. Thanks.
Parts:
LED: CREEXTE-W130 from LEDSupply, current rating 1500mA.
Problem seen:
Parts:
