kochevnik
- Joined
- Jan 17, 2013
- Messages
- 6
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,407
I am a newbie to electronics and since this is an rf system albeit a strange one I thought you guys might have some answers for a project I am working on.
I am working on a project that uses two parallel 'leaky' coax cables to determine when a human being crosses the wires. This is based on student paper (Simon C Wong) that I found on the internet :
Full project pdf at the bottom of that page.
In a nutshell, if you run an RF signal thru coax that is designed to propagate signals, then place a second coax wire about a meter away, the signal in the second wire will be altered by the presence of a human - my basic understanding being that the human acts as an antenna. In the paper Wong used a 150 mhz signal (5 watts ?) and then the human body would be act halfwave antenna.
I'm basically a software guy - I've gotten into digital hardware mcu's and stuff in the last year, this is my first venture into the analog realm. So I bought an old Tek analog scope off ebay, learned how to use it, got an old eico 324 rf signal generator also off ebay and set up two coax wires parallel about 3 feet apart. The first wire (I call the primary) is hooked to the eico red lead and I pumped a bunch of different frequencies down them - tried from 1 to 145 mhz (max on the eico). The secondary coax, acting as the antenna, I hooked to my scope.
One important thing, since I didnt have any 'leaky' coax, I just stripped two coax wires and wire them up so that the signal is output on the shield of the primary and the oscilloscope probe is hooked to the shield on the secondary. From my reading running a signal down the inner core wire would be useless as coax is designed specifically to shield those signals, by 'flipping' the wiring I assumed that the signal would propagate a lot more and be more easily picked up on the secondary. Oh and the secondary I soldered a resistor from the core wire to the shield. Ground from the scope probe is hooked to the ground on the signal output of the eico.
So far so good.
Wired it up, placed the parallel coax on the floor, fired up the eico, sent a bunch of signals thru it from 1 mhz to 145 mhz - and Voila ! when I walk over the secondary cable the signal on the scope literally hops off the screen and then back on. Some freqs seem to work a little better than others, at 36 mhz seems to work best but I think this is because the eico has range knobs and the high range signal is not as strong as the second from the last range.
So here are my main two questions :
1) When I say the signal hops off the scope, I mean that from my view of the scope screen (using human eyeballs) the entire waveform maintains its shape, it just appears to jump up off the screen then come back down - but again, to my view, the amplitude does not appear to change. As a complete newbie I don't understand what phenomenon I am seeing - can someone explain please ? And to add I'm not entirely sure what I am seeing is a real signal or not ?
and 2) Can I use a DAC to 'catch' this signal and process it ? Since from my view the amplitude is not changing, I don't see how the dac would catch this ?
Appreciate any help / advice anyone can give me.
So far so good.
